Another issue is USB connected to a NAS drive
kiwiman2000
Post Tue Jan 15, 2013 5:07 am
Hi
Another issue is when you boot a NAS box the usb drives attached to it that were indexed
can be rearranged.. e.g. N2200
create uncs like //n2200/usbhhd/usb1/1
and ..n2200/.usbhdd/usb#/1 where # can be 1 to 6
where its usb / partition
sometimes what was usb1 is now usb 2
what would be nice is some how the media server detects this
instead of having to rescan usb1 and usb2 again to switch them
I thought perhaps could add a simple text file in root the media server reads
and checks the contents for a settings like
usb1
so then when it checks it looks for the file and then knows usb2 is path
1 that was entered
kiwiman2000
Post Tue Jan 15, 2013 5:09 am
Re: Another issue is USB connected to a NAS drive
im not sure if can get drive volume from the linux NAS for usb drive that could be another way
but a text file might be easier and know it always work then..
if that makes sense what im saying and suggesting?
r-win
Post Sun Jan 20, 2013 10:23 pm
Usually you can change some file like /etc/fstab and use the hardware id to force a static mount. It's easier to solve this on your hardware then in Serviio. You could even write some kind of boot script which would detect which drive is which, and create links to the correct ones.
You are requesting a feature here that hardly anyone experienes, and is absolutely out-of-scope for a mediaserver imo. Of course, it's up to zip, but I think you'll have to start looking to fix this on your NAS.
Linksys WRT320N | Samsung PS-50C7700 | Microsoft XBOX 360 | Windows 8.1 | Linux Ubuntu 13.04
kiwiman2000
Post Mon Jan 21, 2013 4:05 am
i think theres plenty using thecus nas with usb drives attached so its affect them.
whenever they reboot.. if the support didnt fix the problem I dont think I have
a chance
not so easy hacking a n2200 even getting a rootcmd to work is limited
or ssh via modules
just seems silly having to scan all the drives again when all it needs to do is
first update the path to the correct usb location before rescanning
Return to Feature requests
