DVB-S Support
• Page 1 of 1
Would it be possible to stream DVB-S content if the server contains the correct hardware?
Re: DVB-S Support
I have created a live stream using dvbviewer on a seperate computer.
I can use the stream (http://192.168.1.80:2345) on vlc player and it works, however if i add it to serviio it does not appear eventhough i get a green "tick" when i check the stream.
Do i need a plugin?
Do i need a plugin?
Re: DVB-S Support
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
built on Feb 5 2013 21:59:54 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --extra-libs='-lrtmp -l
polarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-
runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-
mingw32- --pkg-config=pkg-config
libavutil 52. 13.100 / 52. 13.100
libavcodec 54. 86.100 / 54. 86.100
libavformat 54. 59.106 / 54. 59.106
libavdevice 54. 3.102 / 54. 3.102
libavfilter 3. 32.100 / 3. 32.100
libswscale 2. 1.103 / 2. 1.103
[h264 @ 014BE7A0] non-existing SPS 0 referenced in buffering period
[h264 @ 014BE7A0] non-existing PPS referenced
[h264 @ 014BE7A0] non-existing PPS 0 referenced
[h264 @ 014BE7A0] decode_slice_header error
[h264 @ 014BE7A0] no frame!
[mpegts @ 014B5AE0] PES packet size mismatch
[h264 @ 014BE7A0] mmco: unref short failure
Last message repeated 1 times
[h264 @ 014BE7A0] Cannot combine reference and non-reference fields in the same
frame
[h264 @ 014BE7A0] If you want to help, upload a sample of this file to ftp://upl
oad.ffmpeg.org/MPlayer/incoming/ and contact the ffmpeg-devel mailing list.
[h264 @ 014BE7A0] reference picture missing during reorder
[h264 @ 014BE7A0] Missing reference picture, default is 65429
frame
[h264 @ 014BE7A0] Missing reference picture, default is 65445
Last message repeated 14 times
[mpegts @ 014B5AE0] Estimating duration from bitrate, this may be inaccurate
Input #0, mpegts, from 'http://192.168.1.80:2345/':
Duration: N/A, start: 21827.967256, bitrate: 192 kb/s
Program 10000
No Program
Stream #0:0[0x93a]: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 19
20x1080 [SAR 1:1 DAR 16:9], 25 fps, 50 tbr, 90k tbn, 50 tbc
Stream #0:1[0x941]: Audio: mp2 ([4][0][0][0] / 0x0004), 48000 Hz, stereo, s1
6p, 192 kb/s
C:\Program Files\Serviio\lib>
Above is the ffmpeg output
frame
frame
Program 10000
No Program
6p, 192 kb/s
Re: DVB-S Support
What do you mean doesn't appear? Make sure to start the stream first, then start Serviio.
Petr
Help translate Serviio
Re: DVB-S Support
under online section on my media player this source never appears even if I restart the server with other pc running.
If I installed the dvb card in the serviio machine would that work?
Sent from my HTC One X using Tapatalk 2
Re: DVB-S Support
Check the log for error message related to adding this stream
Petr
• Page 1 of 1
