Folder Filters for Specific Client Devices
Creepy Gnome
Post Mon Jul 08, 2013 5:26 am
It would be great to be able to apply filters by folders for specific client devices (identified by MAC address).
These would be filters that remove folders and their files from being visible to specific client devices. Usage would be to simplify the view for young children on TV's they typically use, while allow the TV's adults and older children use have more choices.
It would be great if this was in the console GUI, but even an XML config file would be a great start.
Post Mon Jul 08, 2013 6:42 am
Re: Folder Filters for Specific Client Devices
Don't access groups do this for you? see http://www.serviio.org/component/conten ... Nlc3MiXQ==
Creepy Gnome
Post Tue Jul 09, 2013 4:55 am
No they don't if they did I wouldn't be requested this feature. :) I am a pro user and I am familiar with that feature.
See my answer with regards as to why this and my other feature request are not the same as the two fixed global groups.
viewtopic.php?f=3&t=11265
My response in that post if implemented would solve both feature requests.
Return to Feature requests
