Specify folder for a category
secretdk
Post Fri Aug 02, 2013 11:30 am
Would it be possible to implement it so that you can connect a folder on your server to a certain category?
The reason why i'm asking this, is because of the movies category putting my series in it.
Example;
i have a different subfolder for my series and my movies on my server to order them.
When i use the movies category in the mediabrowser it puts anger management and all sorts of series in there.
If i could specify the movies category to my movie folder, then it won't get messed up with different series ending up in my movies category etc.
Thanks in advance.
Post Fri Aug 02, 2013 11:51 am
Re: Specify folder for a category
Not planning this. If you name your files correctly (series), they will only appear in series category
Return to Feature requests
