Folder sorting
tombert
Post Thu Aug 01, 2013 7:19 pm
Folder sorting
Serviio currently sorts the folders like:
Bravo Hits #1
Bravo Hits #10
Bravo Hits #2
I would like to propose sorting also based on [string length] which results in:
Bravo Hits #1
Bravo Hits #2
Bravo Hits #10
For example the Windows Explorer already does it that way.
thx
Post Thu Aug 01, 2013 7:31 pm
Re: Folder sorting
In that case you could end up with
folder A
folder B
folder AB
It'd have to distinguish based on numbers, which might be difficult to do
scottjoc
Post Thu Aug 01, 2013 8:48 pm
Re: Folder sorting
The easiest solution to this is to put a 0 before 1 digit seasons, then sort.
Like so
Season 01
Season 02
Season 10
When I have the folders view in Serviio it displays them in perfect order, but when I look in say the series view it looks like this
Season 1
Season 10
Season 2
I actually prefer the folders view because of this and use Mediarenamer to give the episode titles. I am a bit... OCD on things like this though.
Of course if a show had over 100 seasons it could be a problem again, might need 2 zeroes for that :P (I don't think many does)
Post Thu Aug 01, 2013 10:15 pm
Re: Folder sorting
That yes, and I think 1.3 fixes it for series. But these are actual folders on file system, where Serviio doesn't know some of the characters are numbers.
scottjoc
Post Fri Aug 02, 2013 11:06 am
Re: Folder sorting
On my Xbox 360, if I use the series view, it shows seasons like this:
Season 1
Season 10
Season 2
Windows is guilty of this as well, if you don't stick a 0 in front of them.
I couldn't really know if 1.3 fixes it, I asked to be in the beta but never got a reply so I'll have to take your word on it.
mavack
Post Mon Aug 05, 2013 8:32 am
Re: Folder sorting
It sorts alphabetically just like a library.
With Seasons i always use Season 01 02 03 etc
This is the same for music files from an album most good ripping programs have the ability to force the leading 0
so
01 - name
02 - name
03 - name
so that alphabetical sort works.
tombert
Post Sat Aug 10, 2013 7:20 pm
Re: Folder sorting
zip wrote:In that case you could end up with
folder A
folder B
folder AB
Windows File Explorer (W7) is doing this correctly ... (i tried now).
Whatever sort algorithm Microsoft is using - its cool.
thx
tombert
Post Sat Aug 10, 2013 7:32 pm
Re: Folder sorting
I googled a bit. The sorting I mean is called "natural" or "lexicographical" sorting. Here are some shots for java:
http://www.java2s.com/Code/Java/Collect ... arator.htm
http://stackoverflow.com/questions/1022 ... iendly-way
thx
thomas
Return to Feature requests
