Child /ratings restrictions
• Page 2 of 2 • 1, 2
Thank you, nice job!
Re: Child /ratings restrictions
After installing 1.3.1 the trial version activated and I was able to setup the restrictions I needed. The questions is, after the trial is over, all the restrictions I've set will be cleared/reset (everyone will be able to access everything)?
biggdaniell wrote:After installing 1.3.1 the trial version activated and I was able to setup the restrictions I needed. The questions is, after the trial is over, all the restrictions I've set will be cleared/reset (everyone will be able to access everything)?
Yes, unless you purchase Pro
Petr
Help translate Serviio
Well worth the upgrade to Pro. Best part is MediaBrowser and using ServiiGo. No other server comes close!
zip wrote:biggdaniell wrote:After installing 1.3.1 the trial version activated and I was able to setup the restrictions I needed. The questions is, after the trial is over, all the restrictions I've set will be cleared/reset (everyone will be able to access everything)?
Fair enough, I guess
10x!
