Update overwrites existing files
anniebody
Post Fri Aug 23, 2013 9:54 pm
Each time I update Serviio I have to manually update the ServiioService.exe file with the settings for WDTVLIve. I have tried creating backup files but the next update appears to completely overwrite the bin directory contents. Surely a check for user changes and a prompt is not difficult?
Post Fri Aug 23, 2013 11:50 pm
Re: Update overwrites existing files
which settings? if you mean profiles.xml, it'll create a backup file which you can get your profile from.
nickski
Post Sat Aug 24, 2013 7:59 am
wrong thread!
nickski
Render: Panasonic Viera TX-L42E30B + DMP-BDT210 + Jelly Bean 4.1 Tablet + Onkyo TX-NR616 | Server: Intel i5 Win 7 ult x64 | NW: Homeplug @ 175 Mbps
Return to Feature requests
