SQL connector
bumphere
Post Fri Aug 30, 2013 4:55 pm
SQL connector
I've had a search of the forum, but can't find any references for an SQL conector for the DB.
I think this would be a great addition as it would enable easy library management and would make upgrades simple due to the database not being within the filestructure (I'm thinking for the non tech Uncle / Aunt / Father in Law case rather than power users).
Would this be a good idea?
Cheers
Bump
npuser
Post Sun Sep 01, 2013 3:50 pm
Re: SQL connector
I have no reason to manually manipulate the db so i have not tested this - but i think there is a crude untested db managemnt out there - http://db.apache.org/derby/integrate/SQ ... Derby.html
Give it a go, let us know.
NPuser
Return to Feature requests
