What I would like to see in next release
Betelgeuse
Post Wed Sep 25, 2013 8:32 am
Different user logins with settings for files/folders: Available and Not Available
Possibility to save password at login
Library refresh settings by schedule
Possibility to add a network share to library (like a NAS on the network). At least I have not made that work.
Slideshow function for pictures and possibility to use arrow keys for next/previous picture
Possibility to modify media browser (Style, background image etc.)
Custom port setting
Please comment this!
Post Wed Sep 25, 2013 12:34 pm
Re: What I would like to see in next release
Betelgeuse wrote:Different user logins with settings for files/folders: Available and Not Available
Not going to happen any time soon
Will be in the new MediaBrowser in 1.4
Not planned
Already works.
Up to the renderer, if you mean MediaBrowser it should be included in 1.4
Not going to happen, but 1.4 will have redesigned MB
Custom port setting
Which port?
Betelgeuse
Post Wed Sep 25, 2013 12:57 pm
Good to hear many of my request will happen in MediaBrowser 1.4. Any time for release?
The port I ment is the port Serviio uses (23424).
I will re-test the mapping of my NAS - that would make much easier for me!
Thanks!
spudy12
Post Wed Sep 25, 2013 3:07 pm
Regarding mapping of NAS
What operating system are you using?
If its linux have a look at this post here
viewtopic.php?f=5&t=12234&p=75534#p75534
If its windows map the nas to a drive letter as you would normally then just browse to it from serviio. Make sure to reconnect at login and that your NAS is running the same user account name and password as your pc running serviio is.
My files (on remote drive) are not scanned
Make sure the user that runs Serviio server/service has got access to the shared folders. If you are on Windows, check that the user running the Windows service has got access. To run the service as a different user go to Services (from the Windows Control Panel → Administrative Tools or typing "Services.msc" in the Run command on Start menu), select Serviio, right-click -> Properties, Log On tab, enter the user's details and restart the service.
To access a NAS device the exact same set of credentials must be created on the NAS device. The Windows credentials must be a local user and not a domain user. The user must have "Run As Service" rights. The remote path must be entered as a UNC path in the Serviio Console (e.g. \\server\folder)), mapped drive letters will not work since the user running the Serviio service is not aware of your mapped drives.
Post Wed Sep 25, 2013 3:45 pm
UNC is preferred to drive letter (as per the FAQ entry)
Betelgeuse
Post Thu Sep 26, 2013 8:44 am
Mapping the NAS now works like a charm after running Seriio service with exact same credentials as the NAS!
Return to Feature requests
