Mediabrowser 1.4 Navigation
ghostuw
Post Mon Dec 23, 2013 4:19 pm
Mediabrowser has some menu options such as List View and Queue that are frozen (they don't move when scrolling). It would be very helpful to have the navigation selections (<- Home/Video/Folders etc.) also frozen so you don't have to scroll back to the top to navigate to a new folder.
Also, I understand that Mediabrowser no longer uses the presentation settings. I noticed that it also doesn't use the security settings (even if a Mediabrowser device IP is configured for limited access it still sees everything). Is this by design?
Thanks so much!
Edit: The "Home" key takes you straight to the top so this isn't a big deal
Post Tue Dec 24, 2013 9:13 am
Re: Mediabrowser 1.4 Navigation
MediaBrowser never used the security settings
Return to Feature requests
