select the right audio track based on prefered language
thenamelessthing
Post Tue Dec 31, 2013 4:03 am
Like subtitle, it will be VERY VERY great if serviio can use the right audio track in mkv based on our prefered language.
ex: FR,EN
Actually I have to transcode each file to set the french audio track as the first audio track in the mkv container it's very pain in the ass!
My Setup : BDT220 Panasonic Bluray player, TC-L55ET5 and TC-L42ET5 Panasonic TV. My home media server run Serviio 1.4.2 Pro under GNU/Linux Ubuntu 14.04 LTS server x64 and the hardware is Amd 1045t Phenom II X6, 6Gb DDR3 1333 mhz on SSD and data on soft raid 5 (3x1tb).
thenamelessthing
Post Sun Jan 05, 2014 11:39 pm
Re: select the right audio track based on prefered language
Hi zip, i'm ready to give you 30$ if you can develop this feature or similar (live audio switch when watching a video with multiple audio). I'm pretty sure some other users will add a little amount$$ too for this feature.
Post Mon Jan 06, 2014 12:09 am
A bitbucket requests exists for this: https://bitbucket.org/xnejp03/serviio/i ... ection-for
Joan Murt
Post Tue Jan 14, 2014 3:21 pm
I'm using the MKVMerge GUI software (MKVToolNix ==> http://www.videohelp.com/tools/MKVtoolnix) which it's handy to remove audio tracks and subtitles, it takes seconds for a complete 8GB movie and it's free.
Meanwhile the feature is not there, you can always use that and you won't need to transcode anything.
Return to Feature requests
Users browsing this forum: Baidu [Spider] and 2 guests
