Add property for sql limit clause
drungrin
Post Wed Jan 08, 2014 5:21 pm
Can you parametrize the "FETCH FIRST 1 ROWS ONLY" of the DAO classes (org.serviio.library.dao) so I can replace it with "LIMIT 1" and my mysql edit works fine?
(I reversed it for my own usage, but I want to pay to use the mobile features and keep it updated).
You can add a property on serviio.properties to use the limit, like (default):
limit_statment=FETCH FIRST %d ROWS ONLY
and I can change to:
limit_statment=LIMIT %d
So I can use viewtopic.php?f=6&t=15531 without reverse engineering.
EDIT: CURRENT TIMESTAMP also should have a property. Updating as I get more issues.
Post Mon Jan 13, 2014 5:55 am
Re: Add property for sql limit clause
please create a ticket on Bitbucket and add all the needed changes there.
drungrin
Post Thu Jan 16, 2014 1:28 pm
Filled as Issue #750
Working as a charm on my box.
Return to Feature requests
