Features Availablity
rm3086
Post Mon Jul 28, 2014 8:57 am
I am new to Serviio . I am trying to decide whether to go to Serviio, Plex or stay with Twonky. I was wondering if someone can point me in the right direction to answer the following questions.
Filter file scanning by regex expression (*\thumbs\* or *\OriginalVideo\*)
Status on how many videos, audio, and photos are indexed.
Programmatically start a library refresh for a specific folder.
Is there a file you can modify to change the Shared folders? Currently using the remote console you can add, but not change the settings.
Question everything
Post Mon Jul 28, 2014 2:30 pm
Re: Features Availablity
No. There are some hardcoded.
There is a Status button on the Library tab. It shows the last added file, not how many there are in total.
Yes, but only for the whole library. It might come in future.
No, it's in a database. Remote console lets you add / remove. The REST API lets you even update.
rm3086
Post Tue Jul 29, 2014 6:19 am
That is great to hear. How do I find some of the hard coded folder filter expressions?
Question everything
Post Tue Jul 29, 2014 8:36 am
It's in the code, so you cannot really change that.
Return to Feature requests
