DVD playblack in fullscreen on Samsung A856 LCD TV
jacks87
Post Fri Nov 06, 2009 10:50 pm
A key feature/issue missing from Serviio (and Samsung's own software) is that playing 'DVD format' content does not fill the screen on the TV - just the original pixel/format size which is obviously not 1920x1080. Any way to upsize/upscale this content would be a killer feature and encourage many more users to switch to Serviio. Other than this, it's a really good/usable piece of software!!
Post Sat Nov 07, 2009 11:02 am
Re: DVD playblack in fullscreen on Samsung A856 LCD TV
This would be solved by transcoding, which is not currently supported. Also you can use Newage's firmware (not sure if it will work with your TV)
Aussie
Post Sat Dec 05, 2009 1:42 pm
zip wrote:This would be solved by transcoding, which is not currently supported. Also you can use Newage's firmware (not sure if it will work with your TV)
How do I get Newage firmware and will it work on my B650 in Australia?
Post Sun Dec 06, 2009 1:47 am
Go through this forum, someone already posted link to a website with firmware for B650 that will do this for you...
Return to Feature requests
Users browsing this forum: No registered users and 59 guests
