Show queue as a presentation category
Jimbo
Post Sun Jun 07, 2020 4:23 am
I have been using Serviio since 2014. It's a great server. I use playlists a lot and fixed a few for my wife who doesn't know a thing about computers. She used to come to me to manage the playlists for her until she discovered the queue. The only problem is that the queue does not show as a presentation category on our blu-ray, android or smart tv which limits it to being played on the one computer.
1. can the audio and video queues be added as presentation categories? Manipulating the queue should remain the same.
some time in the future
2. multiple queues that can be individually named
Post Sun Jun 07, 2020 4:33 am
Re: Show queue as a presentation category
Is the queue something specific to your player? I've never seen anything listed as a queue on any of my devices. Exactly what is being queued up?
Jimbo
Post Wed Jun 10, 2020 4:56 am
I am using a windows 10 system as my Serviio server. The queue is only visible on the server and nowhere else.
Upon opening Serviio, the 3 categories, Audio, Image and Video come up. We will use video for the example though audio and image will work as well.
Select video. The sub categories that you have enabled will come up.
At the upper right of the screen 3 icons, Queue, Search, and Logout will show.
Select movies and the thumbnail for the movies will show.
You will notice a plus "+" symbol at the upper right of the thumbnail.
Selecting the "+" in the thumbnail will add that movie to the queue.
A numerical indicator will magically appear at the bottom of the Queue icon and increment for each movie selected. I had as many as 99.
Now select a few more movies then select the Queue icon.
The thumbnail for each movie should show with the letter "X" where the "+" used to be in the upper right right corner of the thumbnail.
Select the "X" in the thumbnail to remove a movie from the queue.
This is one heck of a lot easier than dealing with playlists and is much more dynamic. The shortcoming is that there can be only one queue per main category. I mentioned in my original post that some time in the future, maybe in 2021, multiple queues that can be named by the user could be added .videos from any category or sub folder can be added to the queue.
Post Wed Jun 10, 2020 1:28 pm
OK, you're referring to MediaBrowser. Zip will have to determine if that's something that can be carried over into the regular Serviio presentation categories. You can also add it as a feature request in Bitbucket. That is where Zip keeps track of all feature requests and their status. https://bitbucket.org/xnejp03/serviio/issues
Jimbo
Post Thu Jun 11, 2020 3:27 am
Thank you!
Paul C
Post Fri Sep 04, 2020 8:17 pm
There is already a playlist facility in Serviio (that will do what you want).
You need to create playlists with something like the "m3u Playlist Creator" utility
see https://playlist-creator.en.uptodown.co ... u%20desire.
Put the playlists you create in a folder and identify the folder under serviio console/library/Shared folders as above.
Then make sure you set serviio console/presentation/audio/playlists etc. to "Display Category".
I use them for audio but there options in Serviio under images and video also.
Post Wed Oct 07, 2020 5:30 pm
ATM queues are stored in the browser (in MediaBrowser), not on the server side.
Return to Feature requests
Users browsing this forum: Baidu [Spider] and 20 guests
