XBMC XBOX Transcoding Profile [solved]
servillino
Post Wed Apr 08, 2015 3:19 pm
Hi. i have wrote this profile to convert the video in a SD resolution, but Serviio don't see it in a profile list.
I have insert it in the profiles.xml file. Why don't work?
thank
<Profile id="Custom" name="My XMBC Profile" extendsProfileId="1">
      <!-- Transcode everything  to ensure low bit rate -->
      <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="4000" forceVTranscoding=“true” maxHeight=“360”targetACodec=“mp3" >
         <Matches container="*" />
Post Wed Apr 08, 2015 10:03 pm
Re: XBMC XBOX Transcoding Profile
Did you restart the PC / Serviio service?
servillino
Post Wed Apr 08, 2015 10:13 pm
yes, i have rebbot the system .
I have wrote the profile in the OSX
Library/Application support/Serviio/config/profiles.xml
I think that it's correct
My serviio version is Version 1.5.1
Post Thu Apr 09, 2015 11:06 am
Is it listed in the log after the server starts? It all looks fine from here.
servillino
Post Fri Apr 10, 2015 7:48 pm
I saw the error and I corrected it now.
Serviio start correctly, and try FFMPEG .
2015-04-10 21:41:14,784 INFO  [MediaServer] ------------------------------------------------------------------------
2015-04-10 21:41:14,784 INFO  [MediaServer] Serviio DLNA media streaming server v 1.5.2 (rev. 4b9ce176daa1)
2015-04-10 21:41:14,784 INFO  [MediaServer] Petr Nejedly 2009-2015
2015-04-10 21:41:14,784 INFO  [MediaServer] http://www.serviio.org
2015-04-10 21:41:14,784 INFO  [MediaServer] Java 1.8.0_40-Oracle Corporation x86_64
2015-04-10 21:41:14,785 INFO  [MediaServer] OS Mac OS X 10.10.2
2015-04-10 21:41:14,785 INFO  [MediaServer] File encoding: UTF-8
2015-04-10 21:41:14,785 INFO  [MediaServer] Headless mode enabled: true
2015-04-10 21:41:14,785 INFO  [MediaServer] User: root
2015-04-10 21:41:14,785 INFO  [MediaServer] User home dir: /var/root
2015-04-10 21:41:14,785 INFO  [MediaServer] Temp dir: /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/
2015-04-10 21:41:14,785 INFO  [MediaServer] ------------------------------------------------------------------------
2015-04-10 21:41:16,252 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile xbmc
2015-04-10 21:41:16,252 INFO  [ProfilesDefinitionParser] Added profile 'Xbmc One' (id=xbmc)
2015-04-10 21:41:16,348 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path /Library/Application Support/Serviio/lib/ffmpeg
2015-04-10 21:41:16,356 DEBUG [ProcessExecutor] Starting /Library/Application Support/Serviio/lib/ffmpeg
2015-04-10 21:41:16,429 INFO  [FFMPEGWrapper] Found FFmpeg: ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
servillino
Post Fri Apr 10, 2015 7:50 pm
i have rewrite the enteir profile , but serviio don't force the max Height
the profile now is :
   <Profile id="xbmc" name="Xbmc One" extendsProfileId="1">
      <Detection>
         <UPnPSearch>
            <ModelName>Xbmc One</ModelName>
         </UPnPSearch>
      </Detection>
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="2500" forceVTranscoding="true" maxHeight="480" targetACodec="ac3">
            <Matches container="*" vCodec="h264" aCodec="dca" />
            <Matches container="*" vCodec="h264" aCodec="dts-hd" />
            <Matches container="*" vCodec="h264" aCodec="vorbis" />
            <Matches container="*" vCodec="h264" aCodec="truehd" />
            <Matches container="*" vCodec="h264" aCodec="flac" />
            <Matches container="3gp" vCodec="mpeg4" aCodec="amrnb" />
         <Video targetContainer="mpegts" maxVBitrate="4000" forceVTranscoding="true" maxHeight="360" targetACodec="ac3">
            <Matches container="matroska" vCodec="vc1" />
            <Matches container="wtv" />
            <!-- Matches container="3gp" vCodec="h263" /-->
            <Matches container="flv" />
            <Matches container="ogg" />
            <Matches container="rm" />
            <Matches container="*" vCodec="h265" />
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" forceVTranscoding="true">
                <Matches container="asf" vCodec="mpeg2video" />
                <Matches container="asf" vCodec="mpeg1video" />
               <!--Matches container="adts" /-->
               <Matches container="ape" />
               <Matches container="flac" />
               <Matches container="mpc" />
               <Matches container="wavpack" />
            </Audio>
      <ThumbnailsResolution>HD</ThumbnailsResolution>
Post Sat Apr 11, 2015 1:39 pm
post detailed log of playing a file as well as ffmpeg -i of the file you played and expect to be transcoded
servillino
Post Sun Apr 12, 2015 5:08 pm
this is the ffmpeg -i file
  built on Nov 20 2014 20:39:23 with gcc 4.0.1 (GCC) (Apple Inc. build 5493)
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-librtmp --enable-libfreetype --enable-fontconfig --enable-libass --enable-pthreads --enable-libx264 --enable-libspeex --enable-gpl --disable-mmx --extra-ldflags=-L/Users/MacAdmin/Desktop/build/target/lib --extra-cflags=-I/Users/MacAdmin/Desktop/build/target/include --extra-libs='-lpolarssl -lfreetype -lexpat -liconv'
  libavutil      54. 14.100 / 54. 14.100
  libavcodec     56. 12.101 / 56. 12.101
  libavformat    56. 14.100 / 56. 14.100
  libavdevice    56.  3.100 / 56.  3.100
  libavfilter     5.  2.103 /  5.  2.103
  libswscale      3.  1.101 /  3.  1.101
  libswresample   1.  1.100 /  1.  1.100
  libpostproc    53.  3.100 / 53.  3.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'final_fantasy_xiii_trailer3_hd.mp4':
    major_brand     : isom
    minor_version   : 1
    compatible_brands: isomavc1
    creation_time   : 2009-10-03 12:23:32
  Duration: 00:07:12.47, start: 0.000000, bitrate: 2987 kb/s
    Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 2852 kb/s, 29.97 fps, 29.97 tbr, 30k tbn, 59.94 tbc (default)
      handler_name    : GPAC ISO Video Handler
    Stream #0:1(und): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 132 kb/s (default)
      creation_time   : 2009-10-03 12:23:42
      handler_name    : GPAC ISO Audio Handler
servillino
Post Sun Apr 12, 2015 5:13 pm
and this is the serviio log after i play the video file
2015-04-12 19:11:30,383 INFO  [MediaServer] ------------------------------------------------------------------------
2015-04-12 19:11:30,384 INFO  [MediaServer] Serviio DLNA media streaming server v 1.5.2 (rev. 4b9ce176daa1)
2015-04-12 19:11:30,384 INFO  [MediaServer] Petr Nejedly 2009-2015
2015-04-12 19:11:30,384 INFO  [MediaServer] http://www.serviio.org
2015-04-12 19:11:30,384 INFO  [MediaServer] Java 1.8.0_40-Oracle Corporation x86_64
2015-04-12 19:11:30,384 INFO  [MediaServer] OS Mac OS X 10.10.2
2015-04-12 19:11:30,384 INFO  [MediaServer] File encoding: UTF-8
2015-04-12 19:11:30,385 INFO  [MediaServer] Headless mode enabled: true
2015-04-12 19:11:30,385 INFO  [MediaServer] User: root
2015-04-12 19:11:30,385 INFO  [MediaServer] User home dir: /var/root
2015-04-12 19:11:30,385 INFO  [MediaServer] Temp dir: /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/
2015-04-12 19:11:30,385 INFO  [MediaServer] ------------------------------------------------------------------------
2015-04-12 19:11:30,676 INFO  [WebServer] Socket buffer set to 65535 bytes
2015-04-12 19:11:30,677 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2015-04-12 19:11:30,776 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2015-04-12 19:11:30,776 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2015-04-12 19:11:30,797 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2015-04-12 19:11:30,806 INFO  [DatabaseManager] Using DERBY database language
2015-04-12 19:11:31,803 INFO  [MediaServer] ------------------------------------------------------------------------
2015-04-12 19:11:31,803 INFO  [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2015-04-12 19:11:31,804 INFO  [MediaServer] ------------------------------------------------------------------------
2015-04-12 19:11:31,817 INFO  [Device] Created UPnP Device with UUID: 9734ccd7-cd71-3f5e-b61c-e2ee010d9943, bound address: 10.104.0.74
2015-04-12 19:11:32,414 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2015-04-12 19:11:32,504 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2015-04-12 19:11:32,529 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2015-04-12 19:11:32,534 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2015-04-12 19:11:32,536 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2015-04-12 19:11:32,537 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2015-04-12 19:11:32,542 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2015-04-12 19:11:32,545 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (H-series)' (id=sam_h)
2015-04-12 19:11:32,546 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2015-04-12 19:11:32,548 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2015-04-12 19:11:32,549 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2015-04-12 19:11:32,554 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2015-04-12 19:11:32,561 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013/14)' (id=sony2013)
2015-04-12 19:11:32,562 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2015-04-12 19:11:32,563 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2015-04-12 19:11:32,567 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2015-04-12 19:11:32,568 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2015-04-12 19:11:32,568 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2015-04-12 19:11:32,569 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2015-04-12 19:11:32,571 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2015-04-12 19:11:32,575 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2015-04-12 19:11:32,576 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2015-04-12 19:11:32,579 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2015-04-12 19:11:32,579 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2015-04-12 19:11:32,581 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2015-04-12 19:11:32,581 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2015-04-12 19:11:32,582 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2015-04-12 19:11:32,584 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2015-04-12 19:11:32,584 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2015-04-12 19:11:32,585 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2015-04-12 19:11:32,586 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2015-04-12 19:11:32,588 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2015-04-12 19:11:32,588 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2015-04-12 19:11:32,589 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2015-04-12 19:11:32,589 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2015-04-12 19:11:32,589 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2015-04-12 19:11:32,590 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2015-04-12 19:11:32,591 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2015-04-12 19:11:32,591 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2015-04-12 19:11:32,592 INFO  [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2015-04-12 19:11:32,593 INFO  [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2015-04-12 19:11:32,594 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2015-04-12 19:11:32,595 INFO  [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2015-04-12 19:11:32,595 INFO  [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2015-04-12 19:11:32,597 INFO  [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2015-04-12 19:11:32,597 INFO  [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2015-04-12 19:11:32,598 INFO  [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2015-04-12 19:11:32,599 INFO  [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2015-04-12 19:11:32,599 INFO  [ProfilesDefinitionParser] Added profile 'Xbmc Old' (id=xbmc_old)
2015-04-12 19:11:32,601 INFO  [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2015-04-12 19:11:32,665 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2015-04-12 19:11:32,668 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2015-04-12 19:11:32,669 INFO  [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2015-04-12 19:11:32,670 INFO  [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2015-04-12 19:11:32,671 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2015-04-12 19:11:32,671 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2015-04-12 19:11:32,672 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2015-04-12 19:11:32,672 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2015-04-12 19:11:32,673 INFO  [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2015-04-12 19:11:32,675 INFO  [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2015-04-12 19:11:32,677 INFO  [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2015-04-12 19:11:32,720 INFO  [PluginCompilerThread] Looking for plugins at /Library/Application Support/Serviio/plugins
2015-04-12 19:11:32,720 INFO  [PluginCompilerThread] Started looking for plugins
2015-04-12 19:11:32,724 INFO  [UpdateChecker] Checking if a new version is available
2015-04-12 19:11:32,858 INFO  [FFMPEGWrapper] Found FFmpeg: ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
2015-04-12 19:11:32,892 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2015-04-12 19:11:32,959 INFO  [WebServer] WebServer starting on port 8895
2015-04-12 19:11:32,962 INFO  [Device] Updated bound IP address of Device with UUID: 9734ccd7-cd71-3f5e-b61c-e2ee010d9943, bound address: 10.104.0.74
2015-04-12 19:11:32,979 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-04-12 19:11:32,980 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface en0 (en0) and address 10.104.0.74, timeout = 0
2015-04-12 19:11:32,980 INFO  [EventDispatcher] Starting EventDispatcher
2015-04-12 19:11:32,981 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2015-04-12 19:11:32,986 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2015-04-12 19:11:32,996 INFO  [RendererSearchSender] Searching for Renderer devices
2015-04-12 19:11:41,648 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2015-04-12 19:11:42,321 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2015-04-12 19:11:43,027 INFO  [FileDeltaWatcher] Using 'sun.nio.fs.PollingWatchService' for delta scan
2015-04-12 19:11:59,027 INFO  [FeedUpdaterWorker] Started looking for information about online resources
2015-04-12 19:11:59,027 INFO  [RepositoriesStatusCoordinator$RepositoriesStatusThread] Started checking repositories status
2015-04-12 19:11:59,032 INFO  [LocalLibraryManager] Starting automatic library scan
2015-04-12 19:11:59,107 INFO  [LibraryDeltaScanner] Added repository '/Users/stefano/Downloads/serviiovideo' to delta scanner (POLLER)
2015-04-12 19:11:59,107 INFO  [LibraryDeltaScanner] Starting the library delta scan
2015-04-12 19:11:59,114 INFO  [PlaylistMaintainerWorker] Started looking for playlist changes
2015-04-12 19:12:29,037 INFO  [WebServer] WebServer shutting down
2015-04-12 19:12:29,039 INFO  [EventDispatcher] Leaving EventDispatcher
2015-04-12 19:12:29,038 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2015-04-12 19:12:29,038 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2015-04-12 19:12:29,037 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2015-04-12 19:12:33,040 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
Post Mon Apr 13, 2015 2:40 pm
your profile has no matcher for this file (mp4/h264/aac), so it won't be transcoded (thus leaving the height unchanged)
servillino
Post Fri Apr 17, 2015 10:23 am
i have insert this line :
<Matches container="*" vCodec="h264" aCodec="aac" />
and now ..... it WORK
servillino
Post Fri Apr 17, 2015 12:00 pm
now i use this profile :
      <Detection>
         <UPnPSearch>
         </UPnPSearch>
      </Detection>
         <!-- Transcode h264 videos with profile level > 3.1 to mpegts with ac3 audio -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="4000" maxHeight="480" targetACodec="aac" aBitrate="128" DAR="16:9" forceInheritance="true">
            <Matches container="*" vCodec="h264" profile="high_10" />
            <Matches container="*" vCodec="h264" profile="high" levelGreaterThan="3.1" />
            <Matches container="*" vCodec="h264" profile="main" levelGreaterThan="3.1" />
            <Matches container="*" vCodec="h263" />
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="4000" forceVTranscoding="true" maxHeight="480" DAR="16:9" targetACodec="aac">
            <Matches container="matroska" vCodec="h264" aCodec="mp3" />
            <Matches container="asf" vCodec="wmv2" aCodec="wmav2" />
            </Audio>
I don't convert all h264 file but only h264 videos with profile level > 3.1 , and it work fine .
Tank you ZIP for the help
Return to General discussion
