Running with Seviio with VLC Media Player
dcbailey
Post Fri Jul 17, 2015 6:13 pm
To whom it may concern:
I am attempting serve video to a Video LAN Media Player plug-in using Firefox 39.0
The page is on a Tomcat Server running listening port 8080
When I attempt running the page set in the following manner I get the following error
2015-07-17 12:00:21,100 WARN [ServiioStatusService] ServerUnavailableException occured. Returning error code 503 to the REST layer. Message: Server is not available
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=windows-1252">
<title>New Page 1</title>
</head>
<body>
<embed type="application/x-vlc-plugin"
pluginspage="http://www.videolan.org"version="VideoLAN.VLCPlugin.2"  width="1280"
height="720" id="vlc" loop="yes"autoplay="yes" allowfullscreen="true" target="http://70.113.50.10:23424/resource/cls/90/MEDIA_ITEM/AVC_MP4_MP_HD_720p_AAC-0/ORIGINAL"></embed>
</body>
</html>
If run the page using 8895 it works
<html>
<head>
</head>
<body>
height="720" id="vlc" loop="yes"autoplay="yes" allowfullscreen="true" target="http://70.113.50.10:8895/resource/89/MEDIA_ITEM/AVC_MP4_MP_HD_720p_AAC-0/ORIGINAL/"></embed>
</body>
</html>
I had similar results from the command line.
Interestingly enough looking at what is printed out by VLC I get the following error messages:
[00007fc8f0000e68] http access error: error: HTTP/1.1 404 Not Found
[00007fc8f0000e68] access_mms access error: error: HTTP/1.1 404 Not Found
[00007fc8f80009b8] core input error: open of `http://70.113.50.10:23424/cls/resource/90/MEDIA_ITEM/AVC_MP4_MP_HD_720p_AAC-0/ORIGINAL' failed
It looks like there is a timing issue going on some place.
The question that I have has anyone seen this problem before? If this a problem with Video LAN, could some one suggest another plug-in I could use? I will displaying the web pages on a standard monitor.
Thanks for your help
Dave
dcbailey
Post Fri Jul 17, 2015 8:46 pm
Re: Running with Seviio with VLC Media Player
There seems to be a delay issue with VLC LAN Media Player the following is a workaround
<html>
<head>
<title>Play Video</title>
<script>
function Skip()
   alert ('Click to Play');
   vlc.playlist.pause();
   vlc.input.time = 12000;
function Replay()
</script>
</head>
<body onload="Skip()">
height="720" id="vlc" loop="no"autoplay="yes" allowfullscreen="true" target="http://70.113.50.10:8895/resource/71/MEDIA_ITEM/AVC_MP4_MP_HD_1080i_AAC-0/ORIGINAL"></embed>
<br>
<button type="button" onclick="Replay()">Replay</button>
<script>
</script>
</body>
Post Mon Jul 20, 2015 12:53 pm
try to enable detailed logging
Return to General discussion
Users browsing this forum: Baidu [Spider] and 7 guests
