Cannot see m3u playlists?
ReubenBrown
Post Tue Dec 01, 2020 5:18 pm
I cannot see playlists in my devices nor MediaBrowser
(using v1.9 on Windows XP SP3)
I have added some Audio .m3u playlists in a folder under one of my shared folders.
When I look in MediaBrowser, I cannot see the playlists.
I looked under Audio/Playlists
and the folder containing them via Audio/Folder...
The log shows this
2017-11-26 17:10:18,984 INFO [PlaylistFileIndexer] Added playlist 'TEST.m3u' (title: TEST) to Library
2017-11-26 17:10:19,015 INFO [PlaylistFileIndexer] Added playlist 'TEST_Simple.m3u' (title: TEST_Simple) to Library
The playlist TEST_Simple.m3u is simply
#EXTM3U
F:\LPs\zPlaylists\Test_Neg10dB.mp3
That file was also added successfully to the library.
2017-11-26 17:02:06,828 INFO [MediaFileIndexer] Added file 'F:\LPs\zPlaylists\Test_Neg10dB.mp3' (title: Test_Neg10dB) to Library
I've searched through the forums and it seems no one else has a problem with playlists, so can anyone suggest what could be wrong please?
Post Tue Dec 01, 2020 8:35 pm
Re: Cannot see m3u playlists?
That file doesn't look like it's formatted correctly. Here's the top few lines of one of my M3U files:
#EXTM3U
#EXTINF:5069, -  - 13 Ghosts
F:\Movies\13 Ghosts (1960).mkv
Notice the #EXTINF that yours is missing. This is one reason I mostly use PLS files, as the syntax is much simpler.
Return to General discussion
