Serviio closes 40 minutes on Smart TV when running a movie
braiainog
Post Sun Jun 11, 2023 5:03 pm
My modem is CBN CH8568 from Claro, Brazil. I don't know if the problem is this modem, the cable from the PC and the Wifi from the Smart TV...
When using the cable it closes the Serviio when it arrives in 30 minutes. I changed the Smart tv connection which was by cable and I put it via WI-FI and it lasted 1 hour when playing the movie, but then the Serviio was closed again.
Every 30 minutes Serviio closes and needs to open again, it happened 4 times in a row.
* Modem: CBN CH8568 - 500M Ethernet
* Smart Tv: 40" Full HD Curved Smart TV K6500A Series 6 - UN40K6500
* AMD Ryzen™ 5 5600G
* Windows 10
log
2023-06-11 05:30:18,129 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 05:31:21,943 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 09:56:59,231 INFO  [DiscoveryManager] System wake up detected, restarting UPnP services for network re-discovery
2023-06-11 09:56:59,231 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2023-06-11 09:56:59,231 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2023-06-11 09:56:59,231 INFO  [EventDispatcher] Leaving EventDispatcher
2023-06-11 09:56:59,231 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2023-06-11 09:56:59,294 WARN  [RendererManager] Error while retrieving renderer description: Software caused connection abort: connect
2023-06-11 09:56:59,294 WARN  [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 9 times
2023-06-11 09:56:59,360 WARN  [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 8 times
2023-06-11 09:57:04,434 WARN  [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 7 times
2023-06-11 09:57:09,503 INFO  [Device] Updated bound IP address of Device with UUID: 42adb7ce-4ea5-37fd-b512-d61d947df7e8, bound address: 192.168.0.53
2023-06-11 09:57:09,503 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2023-06-11 09:57:09,503 INFO  [EventDispatcher] Starting EventDispatcher
2023-06-11 09:57:09,503 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2023-06-11 09:57:09,522 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth2 (Realtek Gaming GbE Family Controller) and address 192.168.0.53, timeout = 0
2023-06-11 09:57:27,169 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 09:57:29,227 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 09:58:02,084 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 09:58:04,164 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 09:58:36,216 INFO  [PlaybackEventsManager] Playback of media item 10 (Ta Todo Mundo Louco! - Uma Corrida Por Milhões (2001) Bluray 1080p [Ta Todo Mundo Louco! - Uma Corrida Por Milhões (2001) Bluray 1080p.mp4]) has started at 0% on Identifier=192.168.0.30, Profile=Generic DLNA profile, Name=UN40K6500
2023-06-11 09:59:07,962 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 09:59:10,026 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:00:14,006 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:00:16,081 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:01:20,068 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:01:22,138 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:01:42,727 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:01:44,808 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:02:19,165 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:02:21,241 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:02:26,037 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:02:28,101 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:03:32,116 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:03:34,186 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:04:38,059 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:04:40,137 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:05:44,082 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:05:46,160 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:06:50,199 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:06:52,283 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:07:17,085 INFO  [PlaybackEventsManager] Playback of media item 10 (Ta Todo Mundo Louco! - Uma Corrida Por Milhões (2001) Bluray 1080p [Ta Todo Mundo Louco! - Uma Corrida Por Milhões (2001) Bluray 1080p.mp4]) has stopped at 7% on Identifier=192.168.0.30, Profile=Generic DLNA profile, Name=UN40K6500
2023-06-11 10:07:27,268 INFO  [PlaybackEventsManager] Playback of media item 10 (Ta Todo Mundo Louco! - Uma Corrida Por Milhões (2001) Bluray 1080p [Ta Todo Mundo Louco! - Uma Corrida Por Milhões (2001) Bluray 1080p.mp4]) has started at 0% on Identifier=192.168.0.30, Profile=Generic DLNA profile, Name=UN40K6500
2023-06-11 10:07:45,603 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:07:47,682 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:07:56,356 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:07:58,426 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:09:02,152 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:09:04,213 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:10:08,389 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:10:10,451 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:11:14,304 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:11:16,377 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:11:29,141 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:11:31,217 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:12:20,457 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:12:22,531 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:13:27,669 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:13:29,734 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:14:33,720 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:14:35,762 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:15:39,749 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:15:41,810 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:16:45,786 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:16:47,860 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:17:23,991 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:17:26,064 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:17:51,851 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:17:53,933 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:18:57,820 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:18:59,901 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:20:03,778 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:20:05,837 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:21:09,888 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:21:11,933 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:22:15,893 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:22:17,955 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:23:00,515 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:23:02,581 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:23:21,899 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:23:23,962 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:24:28,058 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:24:30,113 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:25:08,100 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:25:10,170 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:25:33,886 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:25:35,961 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:26:39,919 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:26:41,991 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:27:46,019 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:27:48,083 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:28:48,671 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:28:50,741 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:28:52,785 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:28:54,846 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:29:58,177 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:30:00,256 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:30:17,480 INFO  [PlaybackEventsManager] Playback of media item 10 (Ta Todo Mundo Louco! - Uma Corrida Por Milhões (2001) Bluray 1080p [Ta Todo Mundo Louco! - Uma Corrida Por Milhões (2001) Bluray 1080p.mp4]) has stopped at 20% on Identifier=192.168.0.30, Profile=Generic DLNA profile, Name=UN40K6500
2023-06-11 10:31:04,214 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:31:06,293 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:31:18,156 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:31:20,230 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:31:49,383 INFO  [PlaybackEventsManager] Playback of media item 10 (Ta Todo Mundo Louco! - Uma Corrida Por Milhões (2001) Bluray 1080p [Ta Todo Mundo Louco! - Uma Corrida Por Milhões (2001) Bluray 1080p.mp4]) has started at 0% on Identifier=192.168.0.140, Profile=Generic DLNA profile, Name=UN40K6500
2023-06-11 10:32:10,111 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:32:12,183 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:33:16,224 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:33:18,289 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:34:22,168 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:34:24,236 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:35:28,160 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:35:30,204 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:36:34,219 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:36:36,258 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:37:02,760 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:37:04,817 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:37:40,265 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:37:42,348 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:38:46,347 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:38:48,409 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:39:52,261 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:39:54,330 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:40:58,304 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:41:00,372 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:42:04,358 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:42:06,420 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:42:53,221 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:42:55,282 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:43:10,381 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:43:12,433 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:44:16,447 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:44:18,508 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:45:11,785 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:45:13,839 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:45:22,463 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:45:24,498 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:46:28,545 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:46:30,599 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:47:34,463 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:47:36,504 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:48:40,495 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:48:42,567 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:49:46,526 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:49:48,606 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:50:09,321 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:50:11,397 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:50:52,594 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:50:54,649 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:51:58,644 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:52:00,727 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:52:24,803 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:52:26,871 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:53:04,636 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:53:06,707 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:54:10,685 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:54:12,734 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:55:16,738 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:55:18,814 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:56:22,829 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:56:24,899 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:57:28,803 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:57:30,862 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 10:58:33,961 INFO  [PlaybackEventsManager] Playback of media item 10 (Ta Todo Mundo Louco! - Uma Corrida Por Milhões (2001) Bluray 1080p [Ta Todo Mundo Louco! - Uma Corrida Por Milhões (2001) Bluray 1080p.mp4]) has stopped at 28% on Identifier=192.168.0.140, Profile=Generic DLNA profile, Name=UN40K6500
2023-06-11 11:02:44,492 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:02:46,559 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:06:10,340 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:06:12,396 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:08:43,904 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:08:45,978 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:12:43,738 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:12:45,796 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:16:51,343 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:16:53,379 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:20:19,985 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:20:22,061 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:26:18,596 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:26:20,656 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:26:55,217 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:26:57,271 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:29:43,840 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:29:45,902 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:34:29,446 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:34:31,510 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:40:14,083 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:40:16,144 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:42:27,881 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:42:29,947 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:43:15,754 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:43:17,823 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:47:20,451 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:47:22,510 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:48:03,075 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:48:05,130 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:48:39,849 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:48:41,930 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:52:26,513 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:52:28,586 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:53:28,162 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:53:30,236 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:57:04,841 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 11:57:06,927 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:01:04,454 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:01:06,511 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:05:23,165 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:05:25,245 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:07:42,812 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:07:44,884 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:07:54,659 INFO  [PlaybackEventsManager] Playback of media item 3 (American Made [Feito.na.América.2017.720p.BluRay.x264.DUBLADO-WWW.BLUDV.COM.mp4]) has started at 0% on Identifier=192.168.0.140, Profile=Generic DLNA profile, Name=UN40K6500
2023-06-11 12:11:58,691 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:12:00,753 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:13:35,408 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:13:37,475 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:14:36,066 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:14:38,127 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:15:12,701 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:15:14,768 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:17:08,329 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:17:10,405 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:21:19,918 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:21:21,989 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:25:19,621 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:25:21,683 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:29:48,235 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:29:50,289 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:31:03,803 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:31:05,880 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:32:31,486 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:32:33,559 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:33:08,121 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:33:10,164 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:33:44,847 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:33:46,921 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:35:23,403 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:35:25,482 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:37:53,058 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:37:55,138 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:42:16,627 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:42:18,695 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:43:10,591 INFO  [PlaybackEventsManager] Playback of media item 3 (American Made [Feito.na.América.2017.720p.BluRay.x264.DUBLADO-WWW.BLUDV.COM.mp4]) has stopped at 30% on Identifier=192.168.0.140, Profile=Generic DLNA profile, Name=UN40K6500
2023-06-11 12:43:19,982 INFO  [PlaybackEventsManager] Playback of media item 1 (12 Years a Slave [12 Anos De Escravidão (2014) BRrip 720p Dublado - AndreTPF.mp4]) has started at 0% on Identifier=192.168.0.140, Profile=Generic DLNA profile, Name=UN40K6500
2023-06-11 12:43:38,563 INFO  [PlaybackEventsManager] Playback of media item 1 (12 Years a Slave [12 Anos De Escravidão (2014) BRrip 720p Dublado - AndreTPF.mp4]) has stopped at 2% on Identifier=192.168.0.140, Profile=Generic DLNA profile, Name=UN40K6500
2023-06-11 12:43:38,614 INFO  [PlaybackEventsManager] Playback of media item 3 (American Made [Feito.na.América.2017.720p.BluRay.x264.DUBLADO-WWW.BLUDV.COM.mp4]) has started at 0% on Identifier=192.168.0.140, Profile=Generic DLNA profile, Name=UN40K6500
2023-06-11 12:47:03,237 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:47:05,298 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:49:33,890 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:49:35,967 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:51:48,497 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:51:50,568 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:54:51,067 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:54:53,142 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:57:11,941 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:57:14,019 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:59:40,567 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 12:59:42,643 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 13:03:07,139 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 13:03:09,205 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 13:04:50,744 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 13:04:52,818 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 13:08:41,350 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 13:08:43,428 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 13:12:59,053 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 13:13:01,120 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 13:13:18,993 INFO  [PlaybackEventsManager] Playback of media item 3 (American Made [Feito.na.América.2017.720p.BluRay.x264.DUBLADO-WWW.BLUDV.COM.mp4]) has stopped at 25% on Identifier=192.168.0.140, Profile=Generic DLNA profile, Name=UN40K6500
2023-06-11 13:17:42,707 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 13:17:44,759 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 13:20:31,391 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 13:20:33,463 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 13:22:53,305 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
2023-06-11 13:22:55,374 WARN  [RendererManager] Error while retrieving renderer description: Connection refused: connect
In 2023-06-11 13:17:44 Serviio close from Smart Tv
log4j
<!DOCTYPE log4j:configuration SYSTEM "log4j.dtd">
<!--  Log4j Configuration                                                  -->
<log4j:configuration xmlns:log4j="http://jakarta.apache.org/log4j/" debug="false">
    <appender name="FILE" class="org.apache.log4j.RollingFileAppender">
       <param name="Threshold" value="DEBUG"/>
       <param name="Append" value="true" />
      <param name="File" value="${serviio.home}/log/serviio.log" />
      <param name="MaxFileSize" value="500KB" />
      <param name="MaxBackupIndex" value="5" />
      <param name="Encoding" value="UTF-8" />
      <layout class="org.apache.log4j.PatternLayout">
         <param name="ConversionPattern" value="%d{ISO8601} %-5p [%c{1}] %m%n"/>
      </layout>
   </appender>
   <category name="org.serviio">
      <priority value="INFO"/>
   </category>
   <category name="com.sun.syndication">
      <priority value="ERROR"/>
   </category>
   <category name="org.jaudiotagger">
   </category>
   <category name="org.restlet">
      <priority value="OFF"/>
   </category>
   <category name="LogService"> <!-- Restlet access log -->
   </category>
   <category name="org.apache.jcs">
      <priority value="WARN"/>
   </category>
   <root>
      <appender-ref ref="FILE"/>
   </root>
</log4j:configuration>
Post Sun Jun 11, 2023 8:16 pm
Re: Serviio closes 40 minutes on Smart TV when running a mov
There appears to be an issue with your network, but I can't identify if it's with the computer that is running Serviio, your TV's connection, or something in between. Looking up your modem, I see it's a DOCSYS cable modem. Might that be the issue? Perhaps.
I have cable Internet myself, and while I wasn't experiencing any problems like yours I decided to put my cable modem in bridge mode and use my own personal router to provide my network control. This completely removed the Comcast modem from my network, and I'm much happier with it this way. Your modem likely has the same ability (bridge mode) and you could install your own router and take their box out of the equation.
braiainog
Post Sat Jul 29, 2023 11:38 pm
atc98092 wrote:There appears to be an issue with your network, but I can't identify if it's with the computer that is running Serviio, your TV's connection, or something in between. Looking up your modem, I see it's a DOCSYS cable modem. Might that be the issue? Perhaps.
I found the solution, my modem has 2 wifi settings, 1 wifi is 2.4G and 1 5G so every time I watch a movie the Smart Tv disconnects when the duration exceeds 40 minutes, so I change the wifi to the option "Smart" where to join 2.4G and 5G in one setting, now I can watch movies very well without disconnecting.
Return to General discussion
