Playlist Creator alternative
dlzc
Post Mon Dec 18, 2023 5:49 pm
With Windoze 11, Playlist Creator has stopped working. Drag and Drop, or add files via the built in navigation, you get an error "ding" but no helpful text, and no entry.
listFix seems to work well, just requires Java to be installed.
https://listfix.sourceforge.net/
GusMills
Post Sat Jul 12, 2025 7:04 am
Re: Playlist Creator alternative
dlzc wrote:With Windoze 11, Playlist Creator has stopped working. Drag and Drop, or add files via the built in navigation, you get an error "ding" but no helpful text, and no entry.
https://listfix.sourceforge.net/x trench run
Thank you so much!!
Post Fri Sep 12, 2025 11:07 pm
Rather old thread, but I thought I'd respond anyway. Playlist Creator works just fine with Windows 11. I just used it a couple of days ago. Just be aware that by default Playlist Creator doesn't work for some file types, but they can be added to allowed types in the Settings menu. That was probably the issue the OP ran into.
Return to General discussion
