macOS 26 Tahoe and 2.5
kaoskinkae
Post Mon Jun 08, 2026 4:53 pm
Version 2.4 works perfectly on macOS 26 Tahoe. However, once version 2.5 is installed, there is no network connection and the application menus do not appear, even though the latest available Java version is installed.
zman
Post Wed Jun 10, 2026 10:26 am
Re: macOS 26 Tahoe and 2.5
I've got the same problem. Java up-to-date, security settings, disk access, network settings allow Serviio. Firewall settings checked. Even if firewall is off, doesn't work at all. No sign of Serviio. One thing of interest: UMS doesn't work either. I really have no ideas. Latest Tahoe version.
One addition: commandline says I/O error when launching using
sudo launchctl load -F /Library/LaunchDaemons/org.serviio.server.plist
Load failed: 5: Input/output error
Java says:
% java -version
java version "26.0.1" 2026-04-21
Java(TM) SE Runtime Environment (build 26.0.1+8-34)
Java HotSpot(TM) 64-Bit Server VM (build 26.0.1+8-34, mixed mode, sharing)
Hope anyone has the final solution... I give up.
Post Wed Jun 10, 2026 8:29 pm
zman wrote:One thing of interest: UMS doesn't work either. I really have no ideas. Latest Tahoe version.
That points pretty strongly that it's something in the MacOS that's blocking communications. I'm zero help with a Mac, so have no suggestions.
kaoskinkae
Post Sat Jun 13, 2026 8:30 am
Release Notes 2.5
added authentication to OpenSubtitles integration; ticket #1247
enable to set the Console API port via system properties (serviio.apiHttpPort and serviio.apiHttpsPort); ticket #1245
enable to set the DLNA web server port via system property (serviio.webServerPort); ticket #1245
enable to batch remove Renderers in the Console (status tab); ticket #1183
updated Java to 8u492
added Apple Silicon downloadable
Java macOS Tahoe
java8 Update 491
kaoskinkae
Post Wed Sep 02, 2026 10:00 am
The issue with this version remains unresolved; after so many years of use, I'm considering switching to Plex only.
andeux
Post Thu Sep 03, 2026 9:54 pm
I had the same problem on an Intel Mac running MacOS 15.7.9
Reverting to Serviio 2.4 still works.
So whatever the issue is, it seems to be related to a change in Serviio between 2.4 and 2.5, and not related to the MacOS version.
Return to General discussion
