Home VHS movie identified as Matchbox 20 documentary
mkitchin
Post Fri Jul 08, 2011 1:28 am
I'm converting old VHS tapes to digital. I'm using a 'ads dvd xpress dx2' device for video capture.
I just added my first converted video to serviio. It is a 21 year oldl VHS to mpg conversion. I was very surprised to see what it was identified as.
Added file '1990 - Matthew Wrestling.mpg' (title: VH1 Storytellers - Matchbox Twenty)
ffmpeg.exe -i output is below if that helps at all. Any ideas? I searched for topics on editing metadata, and didn't find a ton.
Thanks for an awesome product!
K:\HomeMovies\VHS>"C:\Program Files (x86)\Serviio\lib\ffmpeg.exe" -i "1990 - Mat
thew Wrestling.mpg" >>c:\temp\mk.txt
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[mpeg @ 0136bef0] max_analyze_duration reached
Input #0, mpeg, from '1990 - Matthew Wrestling.mpg':
Duration: 00:16:46.70, start: 0.213367, bitrate: 5123 kb/s
Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x480 [PAR 8:9 DAR 4:3], 8
000 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc
Stream #0.1[0x1c0]: Audio: mp2, 48000 Hz, 2 channels, s16, 224 kb/s
Post Fri Jul 08, 2011 2:10 am
Re: Home VHS movie identified as Matchbox 20 documentary
What I do for my home movies is have a seperate folder for them and disable online metadata for that folder in the serviio console.
mkitchin
Post Fri Jul 08, 2011 2:55 am
Thanks. I hadn't even noticed that option. I have unchecked it now for my home movies folder. I clicked the button for rescan video metadata. Will it automatically purge the metadata it had already found or do I need to do something manual?
Post Fri Jul 08, 2011 3:29 am
I am not forsure. I will let Zip answer that.
mkitchin
Post Fri Jul 08, 2011 3:34 am
No big deal either way. I had only done a few. I just changed the name slightly to force it to update.
Return to General discussion
