Where does Serviio store its temporary data?
LLoyd
Post Wed Aug 24, 2011 5:47 pm
Does Serviio use the "/var" or "/var/db" directory to store its temporary data before writing it out (permanently) to the serviio directory?
What Serviio files are stored in the "/var" directory (or any of its subdirectories)? Give me the exact names and exact location of where these Serviio files are stored in the "/var" infrastructure.
This is important, because I have software that I want to try with Serviio and if Serviio does store its files (temporarily) in the "/var" directory, then we are talking about a whole different ballgame.
Does somebody have a list of where these Serviio files are temporarily stored?
Post Wed Aug 24, 2011 5:56 pm
Re: Where does Serviio store its temporary data?
no temporary location is used.
LLoyd
Post Wed Aug 24, 2011 6:05 pm
Did earlier version of Serviio use "/var" or "var/db" to store the Serviio library?
I have only used Serviio 0.5.2, but I have read articles across the internet saying that the Serviio library is temporarily stored in the "/var/db" directory. Did older versions of Serviio used to store data in the "/var" or /"var/db" directories?
Post Wed Aug 24, 2011 6:53 pm
LLoyd wrote:Did earlier version of Serviio use "/var" or "var/db" to store the Serviio library?
nope serviio has always stored it library in the same place inside the serviio directory and as zip stated there is NO tempory directory of any kind.
LLoyd
Post Wed Aug 24, 2011 6:59 pm
Thanks guys.
I am going to try FreeNAS 8 with Serviio.
Post Wed Aug 24, 2011 7:04 pm
LLoyd wrote:Thanks guys.
if u need any help on Nas installs post in the NAS section of these forums ( in support section ) and speak to Patters he is the NAS genie here :)
Return to General discussion
Users browsing this forum: Baidu [Spider] and 8 guests
