ffmpeg parmater
ottawaguy
Post Sat Dec 31, 2011 7:12 am
ffmpeg parmater
Hi Zip,
Is there any way I could configure the parameter passed to ffmpeg . I want to tune to bufsize to a larger value. Basically my ffmpeg stream freezes and resumes when i stream padcast from internet. The podcast stream from internet is very fast around 800kbit/sec. I dont have any issue if i watch the stream while downloading is in progressl. I only have issue if i use ffmpeg stream directly from internet. I think there is a buffer issue some where and i want to experiment with it. Any suggestion would be helpful as well.
ottawa.
Post Sat Dec 31, 2011 3:56 pm
Re: ffmpeg parmater
bufsize is only used when restricting video bitrate and is related to video decoder buffer, not download buffer.
ottawaguy
Post Sat Dec 31, 2011 8:03 pm
Re: ffmpeg parmater
Ok got it. Is there any configurable feature in ffmpeg to perform buffering prior to transcoding. i couldnt find any. I would like ffmpeg to have bigger input buffer if possible.
Regards
Ottawa
Post Sun Jan 01, 2012 3:08 pm
Re: ffmpeg parmater
I doubt it, but you can ask at FFmpeg mailing list.
Return to General discussion
