Version 0.6.1 ?
backwards
Post Wed Jan 04, 2012 8:53 pm
Version 0.6.1 ?
I am curious as there is not much talk of the new version 0.6.1 which is currently with the group of beta testers.
I am curious to know how the testing was going.
I am in much anticipation of this as im sure we all are. I know it is very close now and it should have some fixes and new features that will be of great use to me.
I’m checking here a couple of times a day in hope 
I was wondering how close we are to the release being with us?
Panasonic TX-L42D25B
Post Wed Jan 04, 2012 8:55 pm
Re: Version 0.6.1 ?
Within days, hopefully tomorrow.
Post Wed Jan 04, 2012 9:50 pm
Re: Version 0.6.1 ?
backwards wrote:I am curious as there is not much talk of the new version 0.6.1 which is currently with the group of beta testers.
they dont call it closed door testing for nothing ;)
jt323bd
Post Thu Jan 05, 2012 9:14 pm
Re: Version 0.6.1 ?
I'm downloading it as we speak... I can't express my excitement.
Thanks 2.56!
jt323bd
Post Thu Jan 05, 2012 9:27 pm
Re: Version 0.6.1 ?
so far the only user prefrences change I can find appears to be the ability to "edit" online feed URLs.
WildRushSykes
Post Thu Jan 05, 2012 10:29 pm
Re: Version 0.6.1 ?
Zip i dont know if its just me but ive downloaded serviio from the main link windows version and its not installing my cursor is constantly spinning and serviio installer is not appearing ive left it for over 3 minutes and still spinning :(
Post Thu Jan 05, 2012 10:31 pm
Re: Version 0.6.1 ?
works for me, try to download it again
WildRushSykes
Post Thu Jan 05, 2012 10:37 pm
Re: Version 0.6.1 ?
Tried the mirror and worked might just be my box being a bitch :lol:
eclp
Post Fri Jan 06, 2012 7:26 am
Re: Version 0.6.1 ?
Some dialogues are missing in the German translation. Others are faulty.
Where can I find the language files, they would like to customize. Can they please be provided?
Post Fri Jan 06, 2012 7:54 am
Re: Version 0.6.1 ?
eclp wrote:Some dialogues are missing in the German translation. Others are faulty.
viewforum.php?f=16 and if on windows C:\program files\serviio\libs\serviio-client.jar\org\serviio\console\i8n\ ( notice they are inside a JAR file you can open/edit that with winrar )
nickmax1
Post Fri Jan 06, 2012 7:58 am
Re: Version 0.6.1 ?
Wildrushsykes,
I had the same problem trying to install from the main download option, nothing happened for me just a spinning symbol. Downloaded from the mirror and upon double click installed just fine.
Post Fri Jan 06, 2012 8:27 am
Re: Version 0.6.1 ?
yep file on download server seems to be corrupt not valid file but one on mirror work flawlessly.
Return to General discussion
