Serviio 0.6.1 and Live Streams
Post Sun Jan 08, 2012 12:29 pm
Re: Serviio 0.6.1 and Live Streams
I tried it myself, I see all clips on both MEDIUM and HIGH. Medium brings clips with quite low resolution, high with the 800x480 resolution. The plugin has been updated not to include unsupported video codecs which might have changed the clip type appearing for particular quality setting.
Post Sun Jan 08, 2012 1:13 pm
I'll update the plugin again for the next release.
bloody
Post Sun Jan 08, 2012 7:54 pm
In the meanwhile I managed to get the feed from TED's own site. In this case all high quality videos can be accessed.
mkkyah
Post Thu Feb 16, 2012 12:05 pm
CigDangle wrote:My audio streams are valid, I made sure to select "Live Stream", and yet they will not play on my PlayStation 3. My BDP-S370 will play them just fine through Serviio.
The one video stream I have tried, worked just fine on all equipment.
Help!
CigDangle, did you get any solution for PS3 audio stream "unsupported data" error?
edit: found the solution:
viewtopic.php?f=5&t=4786&hilit=ps3+live+stream#p32963
Previous
Return to General discussion
