Serviio Menu System
carmen
Post Sat May 12, 2012 2:53 pm
Serviio Menu System
When I bring up Serviio on my TV, I get the menu that I list below. Is there any way to change this? In Serviio, under library, shared folders, I have a shared a folder called "my movies" I would like to remove all of the below options and just have "my movies".
Thank you
Menu system
Videos
Titles
Series
Last Viewed
Genres
Directors
Online
Movies
Folders
Last Added
Actors
Producers
Post Sat May 12, 2012 2:58 pm
Re: Serviio Menu System
Go into the console, then go to the presentation tab and dissable all the options except folders, and set video to display content only.
This will then give you just 'Folders' with out having to click video, and without the extra options.
carmen
Post Sat May 12, 2012 3:08 pm
Thank you, that has cut down the clutter on the screen. I guess there is no way to simplify it even further so that instead of showing folders, it would just show "my movies" so I can go directly into that folder?
Post Sat May 12, 2012 3:35 pm
Actually yes sorry, if you select Display content only for 'Folders' then you will just get 'my movies [Folders]' and if you untick include parents title, then you should get just 'my movies'
carmen
Post Sat May 12, 2012 4:00 pm
Thank you again for your help
Return to General discussion
