Serviio service not starting
madcarrot2007
Post Fri May 11, 2012 7:39 am
Hi there,
I have been trying a couple days now before posting my problem to the forum. I am running windows xp, I have set password to my windows login account, I have disabled my AVG antivirus firewall and used the default windows firewall, making sure Serviio is in the firewall exception list, i have also updated java from 6 to 7 then reinstalled Serviio, but none of them make the Serviio service started. I'd much appreciated if someone can help me look at my debug log below see what have I missed?
2012-05-11 00:25:55,375 DEBUG [ServiioConsole] Initializing Serviio Console
2012-05-11 00:25:55,390 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2012-05-11 00:25:55,390 INFO [ServiioConsole] Starting Serviio Console
2012-05-11 00:25:55,437 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2012-05-11 00:25:55,484 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-05-11 00:26:05,375 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2012-05-11 00:26:05,375 DEBUG [ServiioConsole] Retrieving preferred console language
2012-05-11 00:26:15,234 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2012-05-11 00:26:15,234 DEBUG [ServiioConsole] Setting console locale to be: en
2012-05-11 00:26:15,234 INFO [Messages] Loaded console message bundle for locale: en
2012-05-11 00:26:25,093 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2012-05-11 00:26:26,703 INFO [ServiioConsole] Leaving Serviio Console
Thank you so much!
Post Fri May 11, 2012 8:16 am
Re: Serviio service not starting
Check if another application use the same port of serviio services.
madcarrot2007
Post Fri May 11, 2012 4:58 pm
Illico wrote:Check if another application use the same port of serviio services.
Hi there, thanks for the quick reply. May I know how to check that and if it is, how do I change its port?
Cheers.
Post Fri May 11, 2012 4:59 pm
post the beginning of the log file
madcarrot2007
Post Fri May 11, 2012 5:08 pm
zip wrote:post the beginning of the log file
Those above in my first post are all the lines in the log file.
Post Fri May 11, 2012 5:11 pm
try to run serviio.bat from serviio/bin directory. See if it gives some error back.
madcarrot2007
Post Sun May 13, 2012 4:33 am
zip wrote:try to run serviio.bat from serviio/bin directory. See if it gives some error back.
Hi there, these are the lines I have got. Cheers!
2012-05-12 21:30:54,453 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2012-05-12 21:30:54,468 INFO [MediaServer] ------------------------------------------------------------------------
2012-05-12 21:30:54,468 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.2 (rev. aec3abd196d6+)
2012-05-12 21:30:54,468 INFO [MediaServer] Petr Nejedly 2009-2011
2012-05-12 21:30:54,468 INFO [MediaServer] http://www.serviio.org
2012-05-12 21:30:54,468 INFO [MediaServer] Java 1.7.0_04-Oracle Corporation
2012-05-12 21:30:54,468 INFO [MediaServer] OS Windows XP x86 5.1
2012-05-12 21:30:54,468 INFO [MediaServer] File encoding: windows-1252
2012-05-12 21:30:54,468 INFO [MediaServer] Headless mode enabled: true
2012-05-12 21:30:54,468 INFO [MediaServer] User home dir: C:\Documents and Settings\Sin
2012-05-12 21:30:54,468 INFO [MediaServer] Temp dir: C:\DOCUME~1\Sin\LOCALS~1\Temp\
2012-05-12 21:30:54,578 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-05-12 21:30:54,625 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-05-12 21:30:54,625 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2012-05-12 21:30:55,859 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2012-05-12 21:30:55,859 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2012-05-12 21:30:55,859 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2012-05-12 21:30:55,859 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2012-05-12 21:30:55,859 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2012-05-12 21:30:55,859 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2012-05-12 21:30:55,859 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2012-05-12 21:30:55,859 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2012-05-12 21:30:55,859 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2012-05-12 21:30:55,859 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2012-05-12 21:30:55,859 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2012-05-12 21:30:56,078 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-05-12 21:30:56,109 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2012-05-12 21:30:56,531 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-05-12 21:30:56,531 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2012-05-12 21:30:56,843 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-05-12 21:30:56,843 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2012-05-12 21:30:57,031 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-05-12 21:30:57,031 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2012-05-12 21:30:57,265 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-05-12 21:30:57,265 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2012-05-12 21:30:57,406 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-05-12 21:30:57,406 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2012-05-12 21:30:57,500 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-05-12 21:30:57,500 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2012-05-12 21:30:57,937 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-05-12 21:30:57,937 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2012-05-12 21:30:57,968 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-05-12 21:30:57,968 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 9
2012-05-12 21:30:58,421 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-05-12 21:30:58,421 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2012-05-12 21:30:59,015 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-05-12 21:30:59,015 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 12
2012-05-12 21:30:59,296 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-05-12 21:30:59,296 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2012-05-12 21:30:59,546 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-05-12 21:30:59,546 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2012-05-12 21:30:59,687 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-05-12 21:30:59,687 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2012-05-12 21:30:59,718 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-05-12 21:30:59,718 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2012-05-12 21:30:59,828 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-05-12 21:30:59,828 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2012-05-12 21:30:59,890 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-05-12 21:30:59,890 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2012-05-12 21:31:00,062 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-05-12 21:31:00,062 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 19
2012-05-12 21:31:00,156 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-05-12 21:31:00,156 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2012-05-12 21:31:00,390 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-05-12 21:31:00,390 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 21
2012-05-12 21:31:00,531 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-05-12 21:31:00,640 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2012-05-12 21:31:00,781 INFO [WebServer] Socket buffer set to 65535 bytes
2012-05-12 21:31:00,781 INFO [Device] Created UPnP Device with UUID: 845849ff-fb73-3682-9791-500c0f07784e, bound address: 192.168.1.68
2012-05-12 21:31:00,812 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\plugins
2012-05-12 21:31:00,812 INFO [PluginCompilerThread] Started looking for plugins
2012-05-12 21:31:00,812 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\lib/ffmpeg.exe
2012-05-12 21:31:00,812 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\lib/ffmpeg.exe
2012-05-12 21:31:00,906 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-05-12 21:31:00,937 INFO [WebServer] WebServer starting on port 8895
2012-05-12 21:31:00,953 DEBUG [DiscoveryManager] UPNP device 845849ff-fb73-3682-9791-500c0f07784e (192.168.1.68) is available
2012-05-12 21:31:00,953 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-05-12 21:31:00,953 INFO [EventDispatcher] Starting EventDispatcher
2012-05-12 21:31:00,953 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-05-12 21:31:00,953 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (NVIDIA nForce Networking Controller - Packet Scheduler Miniport) and address 192.168.1.68, timeout = 0
2012-05-12 21:31:00,953 INFO [RendererSearchSender] Searching for Renderer devices
2012-05-12 21:31:00,953 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-05-12 21:31:00,968 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth0 (NVIDIA nForce Networking Controller - Packet Scheduler Miniport) and address 192.168.1.68, timeout = 0
2012-05-12 21:31:00,968 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2012-05-12 21:31:00,984 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.68:1419
2012-05-12 21:31:01,046 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (NVIDIA nForce Networking Controller - Packet Scheduler Miniport) and address 192.168.1.68, timeout = 0
2012-05-12 21:31:01,046 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 845849ff-fb73-3682-9791-500c0f07784e
2012-05-12 21:31:02,859 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2012-05-12 21:31:06,984 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2012-05-12 21:31:12,875 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (NVIDIA nForce Networking Controller - Packet Scheduler Miniport) and address 192.168.1.68, timeout = 0
2012-05-12 21:31:12,875 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 845849ff-fb73-3682-9791-500c0f07784e
2012-05-12 21:31:14,687 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2012-05-12 21:31:24,687 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (NVIDIA nForce Networking Controller - Packet Scheduler Miniport) and address 192.168.1.68, timeout = 0
2012-05-12 21:31:24,687 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 845849ff-fb73-3682-9791-500c0f07784e
2012-05-12 21:31:26,500 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:27
2012-05-12 21:31:26,984 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-05-12 21:31:26,984 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-05-12 21:31:26,984 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-05-12 21:31:26,984 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-05-12 21:31:27,000 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-05-12 21:31:27,000 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
madcarrot2007
Post Sun May 13, 2012 4:36 am
hmm weird, now i run Serviio console and it seems to appear on my windows tray now. Is it magically working now?
Return to General discussion
