Online Metadata Sources returns wrong titles
snaphook
Post Fri Jul 13, 2012 10:09 pm
I have the first season of Castle (ABC) in .mkv files as Castle S01E01, ...S01E02..., etc. When I go to my Samsung DLNA LED TV and look for them, I see the first 6 episodes with odd titles, names of castles. Apparently there was another show about castles that ran for 6 episodes and the online resources are confused. And if I tell it not to use metadata, none of the files show up in the Series category. Is there a way to direct it so the proper metadata is retrieved?
iheartninjas
Post Sat Jul 14, 2012 2:57 am
Re: Online Metadata Sources returns wrong titles
snaphook wrote:I have the first season of Castle (ABC) in .mkv files as Castle S01E01, ...S01E02..., etc. When I go to my Samsung DLNA LED TV and look for them, I see the first 6 episodes with odd titles, names of castles. Apparently there was another show about castles that ran for 6 episodes and the online resources are confused. And if I tell it not to use metadata, none of the files show up in the Series category. Is there a way to direct it so the proper metadata is retrieved?
Name your files as they are listed at the tvdb. Here is the link http://thetvdb.com/?tab=season&seriesid=83462&seasonid=36354&lid=7. The correct series/folder name would be "Castle (2009)" Rename your files accordingly and then serviio can retireve the correct metadata. :)
Return to General discussion
