Stream a AV input to serviio
adambeef
Post Sat Jul 28, 2012 7:11 am
Hi Guys
Would it be possible to make some sort of plugin to stream a AV input on your laptop/media server out via serviio?
Meaning if i had a satelite box attached to my computer, and serviio running on it - could i stream the satelite box out via serviio?
Adam
Post Sat Jul 28, 2012 8:36 am
Re: Stream a AV input to serviio
If you can get something like VLC to capture it then you can do it in a similar way to streaming your desktop. That would be the easiest to try first.
adambeef
Post Sat Jul 28, 2012 3:43 pm
That shounds pretty good will and could be my answer
So how do i configure serviio to stream my desktop - is there a guide somewhere?
Cheers
Adam
Post Sat Jul 28, 2012 4:57 pm
wiki.serviio.org
Return to General discussion
