Possible BSOD issue
kubbaz
Post Wed May 30, 2012 7:33 am
Possible BSOD issue
Im having an issue, currently under investigation and just want to ask, has anyone ever experienced similar calamaties?
my thread on windows 7 forums, and inparticular a recent development.
http://windows7forums.com/blue-screen-death-bsod/80944-windows-has-recovered-unexpected.html
http://windows7forums.com/blue-screen-death-bsod/80944-windows-has-recovered-unexpected-2.html#post262860
DaFre
Post Thu May 31, 2012 7:52 am
Re: Possible BSOD issue
Hi kubbaz,
I'm having the same issue. See thread http://forum.serviio.org/viewtopic.php?f=5&t=5291&hilit=bsod&start=40
When i disable serviio. The problem doesn't occur.
Unfortunately nobody has replied on the topic since February 11...
kubbaz
Post Sun Jul 29, 2012 6:03 am
The problem reoccurred last night after assuming i had the issue under control. 2 weeks ago, same thing after the issue was initially resolved 4 weeks prior.
same cause every-time, with same seemingly temporary resolution. Disable serviio/Uninstall/Re-install Java
I dont know what the below dmp is describing in a diagnostic sense, but i guess its a start
Debugging Details:
PROCESS_OBJECT: fffffa80080cab30
IMAGE_NAME: _
DEBUG_FLR_IMAGE_TIMESTAMP: 0
MODULE_NAME: _
FAULTING_MODULE: 0000000000000000
PROCESS_NAME: ServiioService
BUGCHECK_STR: 0xF4_ServiioService
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from fffff8000341c882 to fffff800030951c0
STACK_TEXT:
fffff880`078a59c8 fffff800`0341c882 : 00000000`000000f4 00000000`00000003 fffffa80`080cab30 fffffa80`080cae10 : nt!KeBugCheckEx
fffff880`078a59d0 fffff800`033c8e8b : ffffffff`ffffffff fffffa80`086e9060 fffffa80`080cab30 fffffa80`085dd630 : nt!PspCatchCriticalBreak+0x92
fffff880`078a5a10 fffff800`03347f74 : ffffffff`ffffffff 00000000`00000001 fffffa80`080cab30 00000000`00000008 : nt! ?? ::NNGAKEGL::`string'+0x176d6
fffff880`078a5a60 fffff800`03094453 : fffffa80`080cab30 00000000`ffffffff fffffa80`086e9060 00000000`00000000 : nt!NtTerminateProcess+0xf4
fffff880`078a5ae0 00000000`77ae15da : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0cbaf338 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x77ae15da
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
FAILURE_BUCKET_ID: X64_0xF4_ServiioService_IMAGE__
Followup: MachineOwner
***edit
I just installed v1.0 and ofcourse resinstalled Java. Hopefully some unresolved issues may have been sorted
Return to General discussion
