PandaboardES Support
paniko
Post Fri Jan 18, 2013 4:03 pm
Hi Guys,
is possible to install serviio on pandaboard hardware?
Pandaboard ES is a dual core and it support Ubuntu 11.
some of you have already bought and did a bit of experience on this type of hardware "PandboardES"?
this is an example of what PandaBoard can do:
Pandaboard run Ubuntu 11.04 with LCD and Touch
http://www.youtube.com/watch?v=R9rsPAHnk-c
PandaboardES run Android 4.0,support 3G(WCDMA) and GPS
http://www.youtube.com/watch?v=5ziPkUZV ... e=youtu.be
Paniko
Sumsung EU46D6500 | XBox 360 | Samsung Galaxy S 6 Edge | Windows 10 - i7 64bit | Serviio 1.5.2 Pro
Beta Tester
slyguy42o
Post Fri Jan 18, 2013 5:26 pm
Re: PandaboardES Support
There is an ARM build of serviio, but from what I understand the transcoding capabilities are limited.
You might want to check in the NAS sub forum to see if anyone has one of these.
viewforum.php?f=14
paniko
Post Tue Jan 22, 2013 2:47 pm
slyguy42o wrote:There is an ARM build of serviio, but from what I understand the transcoding capabilities are limited.
viewforum.php?f=14
thanks for the info.. i'll pst on the appropriate forum
Paniko
Beta Tester
Return to General discussion
