How increase PQ on web browser
Matixo
Post Mon Feb 11, 2013 7:27 pm
Hi!
I'm newbie on Serviio, and I'd like to improve video PQ over web interface. It lets you change resolution, but there is no bitrate options.
Post Mon Feb 11, 2013 8:17 pm
Re: How increase PQ on web browser
each quality has different bitrare and resolution. You can change it in application-profiles.xml (flv_player profile)
Matixo
Post Mon Feb 11, 2013 9:26 pm
zip wrote:each quality has different bitrare and resolution. You can change it in application-profiles.xml (flv_player profile)
Thanks. Solved.
But it pixels a lot even with a bitrate of 1200 and 480 on resolution
Could I increase compression quality...I mean, in Recording Service (from DVBviewer makers), you can select from normal to extrafast before flowplayer starts.
This software is based on ffmpeg too.
Post Mon Feb 11, 2013 9:55 pm
It's already using the best compression quality (in terms of picture quality) - quantitizer value is 1.
Matixo
Post Mon Feb 11, 2013 10:51 pm
I think Recording Service streams mp4 to web instead of flv.
Enviado desde mi GT-I9100
Return to General discussion
