Can someone plz hlp on Java.io.IOexceptions error below
blindarrow
Post Thu Jun 06, 2013 11:55 pm
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:292)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:209)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:102)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:453)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:94)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:132)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:269)
... 2 more
2013-06-06 12:57:06,700 WARN [FeedUpdaterThread] Failed to retrieve online item information for playpath= pageUrl=http://www.turbotv.in/dangal-tv-live/ swfUrl=http://www.turbotv.in/wp-content/uploads/jw-player-plugin-for-wordpress/player/player.swf live=1. It might not play.
Post Fri Jun 07, 2013 9:44 am
Re: Can someone plz hlp on Java.io.IOexceptions error below
It means the plugin created a wrong media URL.
blindarrow
Post Fri Jun 07, 2013 3:51 pm
Zip,
Thanks for the quick response, Is there anything I could do to fix that...Plus how to get rid of these Java.io.IOexceptions errors...do these belong to same problem u mentioned above...
Return to General discussion
