How to start service and console at same time?
freebo99
Post Mon Jul 29, 2013 2:02 pm
hi
on windows..
i have put service to manual on a slow pc so that it does not start on boot.
i want to start the service and the console at the same time? preferabley by just clicking on serviio console.
and the same for mac osx?
thx
freebo99
Post Mon Jul 29, 2013 3:01 pm
Re: How to start service and console at same time?
instead of running the Windows service you can run Serviio.bat and ServiioConsole.bat from the bin folder. You could write a wrapper bat file that executes them in sequence. I think there might be an example somewhere here, try to search.
Post Mon Jul 29, 2013 3:57 pm
Here is the startserviio.bat I use:
@echo off
: http://support.microsoft.com/kb/251192 how to start a service with sc command
: ensure serviioX console and service is stopped
echo ..
echo Stopping Serviio Service, Serviio, and Console if started...
echo ..
echo This takes about 2 seconds...
call "C:\Program Files\Serviio\bin\serviio.bat" -stop
sc stop serviio
@CHOICE /T 2 /D Y> NUL
echo ..
echo Now Starting Serviio Service and Console.....
echo ..
echo This takes about 4 seconds...
echo ..
sc start serviio
@CHOICE /T 4 /D Y> NUL
start "" "C:\Program Files\Serviio\bin\serviioconsole.exe"
echo ..
echo And 13 seconds to start the Console...
@CHOICE /T 13 /D Y> NUL
Post Mon Jul 29, 2013 5:38 pm
Maybe a wiki article? ;-)
Post Mon Jul 29, 2013 6:39 pm
Actually Cerberus did one long ago.. http://wiki.serviio.org/doku.php?id=startup_win
I just built on it. BTW what happened to him?
Return to General discussion
