problems with some rss files (Solved)
siriusblack
Post Sun Sep 08, 2013 7:30 pm
Hi
Just wondering if anyone else have had the same problem
With these RSS files
https://sites.google.com/site/sportlive ... ivenet.rss
https://sites.google.com/site/neilsrss/ ... ivenet.rss
1 min they work and the next when you restart your computer, The folders
come back But nothing inside them also what I find is if one RSS feeds load all of them do
Beta Tester
siriusblack
Post Sat Sep 14, 2013 8:44 pm
Re: problems with some rss files
Hi All
The Problem is solved with the google RSS Feeds
All I did was opened the livefeed plugin with notepad++
Copied the Test RSS feed which is this
https://sites.google.com/site/serviiors ... N_News.rss
Put this in serviio console up the top of the list
Been working ever since
Hope this helps anyone who had the same problem
Beta Tester
siriusblack
Post Fri Sep 20, 2013 7:33 pm
Unfortunately it's not solved
The google RSS feeds has stopped working again
What do you recommend I should do please ?
Thanks any advice would be grateful
Beta Tester
siriusblack
Post Sat Sep 28, 2013 1:09 pm
Hi
If anyone had the same problem
Here is the livefeed to use
LiveFeeds.groovy
(2.69 KiB) Downloaded 682 times
Hope this helps you, cause it fixed my problem
Beta Tester
Return to General discussion
