install
raytraci
Post Tue Apr 29, 2014 2:17 pm
install
Trying to install without luck I get a pop up saying "This file does not have a program associated with it for performing this action. Please install a program or, if one is already installed, create an association in the default programs control panel"
Not sure what to do.
Ray
Post Tue Apr 29, 2014 4:40 pm
Re: install
Does the downloaded file have .exe extension? If not, try to download it from the mirror of using a different browser.
raytraci
Post Wed Apr 30, 2014 1:19 am
Re: install
Thank you for your help Serviio installed.
Ray
Return to General discussion
