install problem
enoemos
Post Sun May 18, 2014 9:19 pm
install problem
just downloaded this for my mac, when i open the console it sits in the tray and but when i open the other one it bounces a couple of times then disappears?
any help would be appreciated!!!
Post Mon May 19, 2014 12:51 pm
Re: install problem
That is probably ok, the server application is probably just running in the background.
lockstock
Post Mon May 26, 2014 5:44 pm
Re: install problem
I am having exactly the same problem but it then goes on to say that the application is not responding. Any ideas?
flozano
Post Mon Jun 02, 2014 5:04 am
Re: install problem
This is a problem in Mac OS X and Java 8. The server is *not* running in the background.
If you launch by console you get:
$ open /Applications/serviio/Serviio.app/
LSOpenURLsWithRole() failed with error -10810 for the file /Applications/serviio/Serviio.app.
flozano
Post Mon Jun 02, 2014 5:08 am
Re: install problem
Also when ran manually, you get:
/Applications/serviio/Serviio.app/Contents$ ./MacOS/JavaApplicationStub
JavaVM: Failed to load JVM: /Library/Java/JavaVirtualMachines/jdk1.8.0_05.jdk/Contents/Home/bundle/Libraries/libserver.dylib
JavaVM FATAL: Failed to load the jvm library.
[JavaAppLauncher Error] JNI_CreateJavaVM() failed, error: -1
Return to General discussion
