Issues with .ASX playlists
Post Mon Jan 26, 2015 3:11 pm
Re: Issues with .ASX playlists
Headbolt wrote:Can you see another method of achieving what I am trying to achieve within Serviio.
Nope, unless you split the files yourself.
How do I log it as a feature request ?
viewtopic.php?f=5&t=2
Headbolt
Post Mon Jan 26, 2015 10:56 pm
OK thank you, have logged it
#847
Hope it is something that can be looked at some time soon, hopefully its a quick and easy feature to add and it will happen.
Thanks for your help, I will test relative paths as soon as 1.5.1 is available and reply with my results.
Headbolt
Post Thu Feb 26, 2015 10:02 pm
I see 1.5.1 is released and the relative paths bug has been fixed.
Is there any news on when the .ASX playlist features might be added ?
Post Fri Feb 27, 2015 10:02 pm
Doubt it will be anytime soon.
Previous
Return to General discussion
