always enable burned-in subtitles serviio 1.6.1 missing
pluckey
Post Thu Mar 31, 2016 5:11 am
In version 1.5.2 under subtitles -> Enable burned-in subtitles, there is an option to Always use burned-in subtitles which works great, this option i don't see it on the new version 1.6. is there a way to enable this or bring it back? with this option i'm able to read subtitles better as it has an embeded outline around the subtitle which makes it more legible.
Post Thu Mar 31, 2016 8:35 am
Re: always enable burned-in subtitles serviio 1.6.1 missing
There is still the option to enable Burned-in subtitles. If you want that even if your device supports soft subtitles, you need to change the profile you're using to add/ replace the Subtitles block with
<Subtitles>
         <SoftSubs mime-type="text/srt" />
         <HardSubs>
            <BitmapBased supported="true"/>
            <TextBased supported="true">
               <RequiredFor container="*"/>
            </TextBased>
         </HardSubs>
      </Subtitles>
pluckey
Post Sat Apr 02, 2016 2:59 pm
how do i change the subtitle block and profile?
Return to General discussion
