previous version
rodrigoitaqui
Post Sun Apr 15, 2018 4:44 pm
previous version
Someone has the link of version 1.5.2 because all the test I did this version is stable, which works best in my network can advance the movie and return without giving an invalid file error. please if someone has the link sent.
Post Sun Apr 15, 2018 6:14 pm
Re: previous version
rodrigoitaqui wrote:Someone has the link of version 1.5.2 because all the test I did this version is stable, which works best in my network can advance the movie and return without giving an invalid file error. please if someone has the link sent.
That version is significantly older. Are you sure you need to step back that far? Anyway, you can download previous versions by copying the download link from the main Serviio page and changing the version number to the desired version.
rodrigoitaqui
Post Thu Apr 19, 2018 5:09 am
I did not find this option to choose other versions, because it is not on the site, could send the link ???
rodrigoitaqui
Post Thu Apr 19, 2018 12:17 pm
There is no page with links to older versions. You have to edit the download URL as I mentioned with the version number you desire.
Post Sun Apr 22, 2018 3:30 am
There is a repository of the old versions here: https://www.videohelp.com/software/Serviio/old-versions
This site is not affiliated with Serviio in any way, so make sure you use normal precautions (virus scan files, etc). Better to source the originals by modifying the URLs as per atc98092 post.
Return to General discussion
