HDMI connection replaced by DLNA
XP-Dolf
Post Fri Sep 16, 2011 3:11 pm
My PC is in the same room as the TV.
I have a wireless keyboard and mouse.
The PC monitor and TV are both Full HD quality.
If I want to see the PC monitor on the TV I must use a HDMI cable connection.
Is it possible to stream a copy of the PC monitor to the TV througt the DLNA server?
With LogMeIn, Teamviewer, PC-anywhere it is possible too so why is it not in the dlna server?
Dolf
patters
Post Fri Sep 16, 2011 3:41 pm
Re: HDMI connection replaced by DLNA
This gets asked about a lot and I think Zip mentioned that he would take a look at it. Remember though that it will never be as good as a direct connection. It will most likely be mpeg2video and would require a high bitrate to show high resolutions (making it unsuitable for wifi for instance). It would also be useless for gaming since there would be some encoder lag. But I suppose it could be useful for basic web browsing, or email.
Post Fri Sep 16, 2011 4:38 pm
stick to HDMI it will be much better than anythign DLNA can offer.
Post Sat Dec 03, 2011 9:56 pm
DVI (digital video interface) and HDMI ( HD multimedia interface ) are the same other than HDMI carrys the audio signal as well as video. :)
Post Sun Dec 04, 2011 4:47 am
XP-Dolf wrote:Is it possible to stream a copy of the PC monitor to the TV througt the DLNA server?
Yes this is quite possible and I have it working now with the 6.1 beta. Resolution is 1280x720, and the latency is about 3 seconds.
Its real use is to be able to display any full screen flash video available on the web on the TV, particularly those using RTMP/RTMPE with DRM that you will never be able to get a livestream link for.
sampath.mamilapo
Post Fri Dec 16, 2011 3:42 pm
Where can I download the 0.61 beta? Can I join the beta program?
Cheers,
Sampy
Return to General discussion
Users browsing this forum: Baidu [Spider] and 21 guests
