current title of song
hendrysetiadi
Post Mon Dec 18, 2023 8:04 am
How to display current title of song including with the artist on the internet radio streams ?
Post Mon Dec 18, 2023 3:45 pm
Re: current title of song
If they offer the name in the stream, it should be shown. If there's nothing there then they likely don't provide it in the stream. Nothing Serviio can do to change that.
hendrysetiadi
Post Sat Dec 23, 2023 7:17 am
They actually provide that information..but it does not show on DLNA devices. Any setting should be added?
atc98092 wrote:If they offer the name in the stream, it
Post Sat Dec 23, 2023 4:41 pm
If the Internet stream requires the use of a plug-in config file, it might be something that can be adjusted there. If no plug-in is required, then there's nothing further Serviio can do to adjust the stream. I just looked in the console and there's no settings to be made for Internet streams.
hendrysetiadi
Post Sun Dec 31, 2023 11:37 am
How to know the internet stream requires a plugin?
On my dlna devices (Denon), i can see the id3 tag displayed on the radio station list when playing the stream. Why serviio cannot show the id3 tag also?
atc98092 wrote:If the Internet stream requires the use of a plug-in config file, it might be something that can be adjusted there. If no plug-in is required, then there's nothing further Serviio can do to adjust the stream. I just looked in the console and there's no settings to be made for Internet streams.
Post Sun Dec 31, 2023 9:24 pm
hendrysetiadi wrote:How to know the internet stream requires a plugin?
If you didn't need to install a plug-in for it to work, then no plug-in is required. I can't say why your Denon is displaying the tag, but it's not using DLNA to stream the station. That is using a different protocol from DLNA, so that could explain why the Denon displays the information. I don't know enough about Internet streaming to help much further. Hopefully the Serviio developer will see this thread and offer some assistance.
Return to Audio streams
