Problem with many m4a (alac) files
radamo
Post Sat May 02, 2015 11:56 am
I just downloaded Serviio yesterday and it seems to be very well done. I do have a ton of files that are not showing on my PS3. I have a Win7 x64 pc and use iTunes to manage my music. Most of my music are from CD's which were imported into iTunes as Apple Lossless. Some albums show up and others do not. How do I solve this?
Thank you.
Post Tue May 05, 2015 5:29 pm
Re: Problem with many m4a (alac) files
Apple lossless is not supported yet.
NickJP
Post Sun May 17, 2015 3:16 am
If you do add support for Apple lossless, can you also add an option to *not* add these files to the library. I have all my CDs both ripped as lossless, for playing through a decent HiFi, and I've also created AAC versions of all these files for use on the iPod in the car etc, as the lossless tracks exceed the storage capacity of the iPod.
Wixie
Post Sun May 17, 2015 10:21 pm
Will Alac ever be supported? Because People asking for years(!!) for Alac Support. Ffmpeg also Supports Alac so adding Support for that Format should not be a big deal or?
Users browsing this forum: Baidu [Spider] and 40 guests
