New movie detection & connection break ver.1.5.2
toasted
Post Sun May 31, 2015 10:58 am
Hi!
I´m using serviio pro and i´m very happy with this software. But since the update to 1.5.2 I got two problems:
1.) Serviio detects new movies even if they are already in the database. Every day another path is affected of this problem. For example:
On monday all movies at \\nas\A\ are detected as new movies
On tuesday all movies at \\nas\B\ are detected as new movies...
Latest serviio logfile:
2015-05-30 16:46:30,665 INFO  [MediaFileIndexer] Removing 'Bad Boys II' (\\nas\Filme\B\Bad Boys 2.mkv) from Library
2015-05-30 16:46:30,742 INFO  [MediaFileIndexer] Removing 'Bad Boys - Harte Jungs' (\\nas\Filme\B\Bad Boys.mkv) from Library
2015-05-30 16:46:30,809 INFO  [MediaFileIndexer] Removing 'Bad Teacher' (\\nas\Filme\B\Bad Teacher.mkv) from Library
2015-05-30 16:48:14,269 INFO  [MediaFileIndexer] Added file 'Bad Boys 2.mkv' (title: Bad Boys II) to Library
2015-05-30 16:48:16,327 INFO  [MediaFileIndexer] Added file 'Bad Boys.mkv' (title: Bad Boys - Harte Jungs) to Library
2015-05-30 16:48:19,085 INFO  [MediaFileIndexer] Added file 'Bad Teacher.mkv' (title: Bad Teacher) to Library
2015-05-31 00:30:22,020 INFO  [MediaFileIndexer] Removing 'Eagle Eye - Außer Kontrolle' (\\nas\Filme\E\Eagle Eye.mkv) from Library
2015-05-31 00:30:22,694 INFO  [MediaFileIndexer] Removing 'Earth to Echo' (\\nas\Filme\E\Earth to Echo - Ein Abenteuer so groß wie das Universum (2014).mkv) from Library
2015-05-31 00:30:22,941 INFO  [MediaFileIndexer] Removing 'Eden Log' (\\nas\Filme\E\Eden Log.mkv) from Library
2015-05-31 00:30:23,550 INFO  [MediaFileIndexer] Removing 'Edge of Tomorrow' (\\nas\Filme\E\Edge of Tomorrow (2014).mkv) from Library
2015-05-31 00:32:04,009 INFO  [MediaFileIndexer] Added file 'Eagle Eye.mkv' (title: Eagle Eye - Außer Kontrolle) to Library
2015-05-31 00:32:06,106 INFO  [MediaFileIndexer] Added file 'Earth to Echo - Ein Abenteuer so groß wie das Universum (2014).mkv' (title: Earth to Echo) to Library
2015-05-31 00:32:08,527 INFO  [MediaFileIndexer] Added file 'Eden Log.mkv' (title: Eden Log) to Library
2015-05-31 00:32:10,795 INFO  [MediaFileIndexer] Added file 'Edge of Tomorrow (2014).mkv' (title: Edge of Tomorrow) to Library
Logfile attached
2. Connection break after about 30-45 minutes
The connection breaks after 30-45 minutes to my Samsung UE37ES5700. This problem only appears in the LAN, over WAN everything is okay.
What I already tested:
1. New installation of serviio
2. Removed my switch / new installation of serviio / firmwareupdate on the TV and D-LAN Adapters / Note: I didn´t have this problem with 1.5.1
I hope you can give me a hint for a solution..
Best regards from Austria,
Daniel
pc5dczc_log.txt
(39.68 KiB) Downloaded 446 times
toasted
Post Tue Jun 02, 2015 11:05 am
Re: New movie detection & connection break ver.1.5.2
Today i tested a downgrade to 1.5.1.. unfortunately the connection breaks after about 30 minutes too. So I think I have to check my network again.. But the movie detection works without any problems with this version..
toasted
Post Thu Jun 04, 2015 10:55 am
I found a solution for my problem with the connection breaks:
The allocated IP-address in Serviio´s network settings was set to automatic. I use 2 network connections on this computer (10.0.x.x and 192.168.x.x). With a manual allocation of the IP, the connection problems was gone.
best regards from Austria,
Daniel
