trying to get subtitles to work
freaknik
Post Mon Jul 06, 2015 2:59 pm
:mrgreen:
I have mkv's with hard subs that won't ever show on serviio.
The video and audio play, but no subtitles.
The devices I am using are a chromecast and a panasonic bluray bdt230.
Here is the file info for one of the files:
C:\Program Files\Serviio\lib>ffmpeg -i "C:\Users\Max\Videos\Dragon Ball Super 72
0p - 001.mkv"
ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
  built on Nov 19 2014 22:12:09 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --enab
le-libspeex --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype
-lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-
os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config
  libavutil      54. 14.100 / 54. 14.100
  libavcodec     56. 12.101 / 56. 12.101
  libavformat    56. 14.100 / 56. 14.100
  libavdevice    56.  3.100 / 56.  3.100
  libavfilter     5.  2.103 /  5.  2.103
  libswscale      3.  1.101 /  3.  1.101
  libswresample   1.  1.100 /  1.  1.100
  libpostproc    53.  3.100 / 53.  3.100
Input #0, matroska,webm, from 'C:\Users\Max\Videos\Dragon Ball Super 720p - 001.
mkv':
    encoder         : libebml v1.3.1 + libmatroska v1.4.2
    creation_time   : 2015-07-05 11:24:37
  Duration: 00:23:24.47, start: 0.000000, bitrate: 712 kb/s
    Stream #0:0: Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 23.98
 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
      BPS             : 662904
      BPS-eng         : 662904
      DURATION        : 00:23:24.320000000
      DURATION-eng    : 00:23:24.320000000
      NUMBER_OF_FRAMES: 33670
      NUMBER_OF_FRAMES-eng: 33670
      NUMBER_OF_BYTES : 116366173
      NUMBER_OF_BYTES-eng: 116366173
      _STATISTICS_WRITING_APP: mkvmerge v7.8.0 ('River Man') 32bit built on Mar
27 2015 16:18:02
      _STATISTICS_WRITING_APP-eng: mkvmerge v7.8.0 ('River Man') 32bit built on
Mar 27 2015 16:18:02
      _STATISTICS_WRITING_DATE_UTC: 2015-07-05 11:24:37
      _STATISTICS_WRITING_DATE_UTC-eng: 2015-07-05 11:24:37
      _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
      _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
    Stream #0:1(jpn): Audio: aac (HE-AAC), 48000 Hz, stereo, fltp (default)
      BPS             : 47992
      BPS-eng         : 47992
      DURATION        : 00:23:24.459000000
      DURATION-eng    : 00:23:24.459000000
      NUMBER_OF_FRAMES: 32917
      NUMBER_OF_FRAMES-eng: 32917
      NUMBER_OF_BYTES : 8425485
      NUMBER_OF_BYTES-eng: 8425485
27 2015 16:18:02
    Stream #0:2(jpn): Subtitle: subrip (default)
      BPS             : 47
      BPS-eng         : 47
      DURATION        : 00:23:11.700000000
      DURATION-eng    : 00:23:11.700000000
      NUMBER_OF_FRAMES: 271
      NUMBER_OF_FRAMES-eng: 271
      NUMBER_OF_BYTES : 8191
      NUMBER_OF_BYTES-eng: 8191
27 2015 16:18:02
Can someone help me watch these with subtitles on my tv? Thanks
Post Sat Jul 11, 2015 10:32 am
Re: trying to get subtitles to work
Did you enable Embedded subtitles and use 'jpn' as the preferred language for subtitles?
Note that embedded subs will not always work, as it may take ages to extract the file and the TV in the meantime times out.
freaknik
Post Wed Jul 15, 2015 4:57 pm
yes, it looks like that's what is happening.
I guess I can always rip the subs to a same named srt and place that in the same folder and it should work.
Thanks, I guess it's asking a lot to play a movie while extracting subtitles and play it all to my tv instantly.
I wanted to learn Japanese anyway.
thanks zip
Users browsing this forum: No registered users and 50 guests
