Librarys won"t shiow & NO postersdisplay
mikesmedia1
Post Fri Aug 21, 2015 10:06 pm
Hi
I've got serviio running on a laptop streaming to a ps3.
The MOVIES and TV SHOWS under VIDEOS show nothing or "no titles" but every other folder works fine.
I've reinstalled it but nothing. The only way to access them is thru FOLDERS or GENRES.
Also no posters display. It's the only part of the metadata that never get grabbed.
THX
Mike
Post Fri Aug 21, 2015 10:36 pm
Re: Librarys won"t shiow & NO postersdisplay
Actually, it sounds like no metadata is grabbed. Therefore, Serviio doesn't know if the file is a movie or TV series and doesn't display anything.
What format are you using to name the files? On the Metadata tab on Serviio Console what source are you using for metadata retrieval?
Post Sun Aug 23, 2015 8:14 am
See http://www.serviio.org/component/conten ... extraction especially the bit about naming your files.
Users browsing this forum: Baidu [Spider], Google [Bot] and 27 guests
