m4v m4a HEVC not working
Skullpuck
Post Sat Aug 29, 2015 7:18 pm
I've just recently switched to Serviio from PS3 Media Server because PS3MS couldn't play M4V or M4A files encoded with h. 265 HEVC.
Serviio states that it supports these formats and will transcode when needed. Unfortunately, when I try to access these files in any DLNA device they do not play.
I've tried, Kodi and my Samsung DLNA TV.
I have attached my log files from Kodi and Serviio. This is the media information from one of the files.
Does anyone have a suggestion on what I can do?
Complete name                            : \\Gmserver5\e\Gunk\Friends\Friends Season 02 (1080p x265 Joy)\Friends S02E01 The One with Ross's New Girlfriend (1080p x265 Joy).m4v
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42
File size                                : 164 MiB
Duration                                 : 22mn 13s
Overall bit rate                         : 1 033 Kbps
Movie name                               : Friends s 02 (1995) - for Hurtom & TNU by Tenax555 & smak2001
Writing application                      : HandBrake 0.10.1 2015030800
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main@L4@Main
Codec ID                                 : hev1
Codec ID/Info                            : High Efficiency Video Coding
Duration                                 : 22mn 12s
Bit rate                                 : 900 Kbps
Height                                   : 1 080 pixels
Frame rate mode                          : Variable
Minimum frame rate                       : 23.974 fps
Maximum frame rate                       : 23.981 fps
Bits/(Pixel*Frame)                       : 0.018
Stream size                              : 143 MiB (87%)
Writing library                          : x265 1.5:[Windows][GCC 4.9.0][64 bit]
Encoding settings                        : wpp / ctu=64 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / no-early-skip / no-fast-cbf / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / fast-intra / open-gop / interlace=0 / keyint=240 / min-keyint=24 / scenecut=40 / rc-lookahead=15 / bframes=4 / bframe-bias=0 / b-adapt=0 / ref=2 / weightp / no-weightb / aq-mode=1 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=2 / psy-rd=0.30 / psy-rdoq=0.00 / signhide / lft / sao / no-sao-non-deblock / b-pyramid / cutree / rc=2 / pass / bitrate=900 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30
Color range                              : Limited
Format profile                           : HE-AAC / LC
Codec ID                                 : 40
Duration                                 : 22mn 13s
Bit rate                                 : 128 Kbps
Channel(s)_Original                      : 6 channels
Sampling rate                            : 48.0 KHz / 24.0 KHz
Stream size                              : 20.3 MiB (12%)
Title                                    : Surround / Surround
Text
Format                                   : Timed Text
Muxing mode                              : sbtl
Codec ID                                 : tx3g
Duration                                 : 22mn 9s
Bit rate                                 : 80 bps
Stream size                              : 12.9 KiB (0%)
(317.91 KiB) Downloaded 456 times
kodi.log
(74.87 KiB) Downloaded 457 times
Post Tue Sep 01, 2015 11:28 am
Re: m4v m4a HEVC not working
I don't see any attempt to play the file in serviio.log..?
Users browsing this forum: Baidu [Spider] and 37 guests
