Cannot connect to server
DLNA Dummy
Post Sat Nov 21, 2015 9:43 am
Hi
I installed Serviio and when I launched the console for the first time, it was working fine. But after a PC reboot, it stopped working giving the error "Cannot connect to Serviio Server, it does not seem to be running. Exiting"
I looked around here in the board for help and updated my Java to the latest Version (Version 8 update 66). Then i uninstalled and reinstalled Serviio. Did not help. Again, console was working as long as I did not reboot the PC.
Am using Win 7 32bit, Serviio 1.5.2
Here is the log file:
2015-11-21 01:20:11,755 INFO [ServiioConsole] Initializing Serviio Console
2015-11-21 01:20:11,802 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2015-11-21 01:20:11,817 INFO [ServiioConsole] Starting Serviio Console
2015-11-21 01:20:11,973 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2015-11-21 01:20:12,067 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2015-11-21 01:20:12,067 DEBUG [ServiioConsole] Checking if server is running
2015-11-21 01:20:22,472 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2015-11-21 01:20:22,472 DEBUG [ServiioConsole] Retrieving console settings
2015-11-21 01:20:32,675 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - The connector failed to connect to the server
2015-11-21 01:20:32,675 INFO [Messages] Loaded console message bundle for locale: en
2015-11-21 01:20:36,637 INFO [ServiioConsole] Exitting Serviio Console
2015-11-21 10:33:21,153 INFO [ServiioConsole] Initializing Serviio Console
2015-11-21 10:33:21,199 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2015-11-21 10:33:21,199 INFO [ServiioConsole] Starting Serviio Console
2015-11-21 10:33:21,371 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2015-11-21 10:33:21,449 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2015-11-21 10:33:21,449 DEBUG [ServiioConsole] Checking if server is running
2015-11-21 10:33:31,932 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2015-11-21 10:33:31,932 DEBUG [ServiioConsole] Retrieving console settings
2015-11-21 10:33:42,150 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - The connector failed to connect to the server
2015-11-21 10:33:42,150 INFO [Messages] Loaded console message bundle for locale: en
Any idea? Obviously, i dont want to do a new install each time i want to use Serviio ;)
Thanks!
Post Sun Nov 22, 2015 1:29 am
Re: Cannot connect to server
Wrong log. Try this:
  • Rename "C:\Program Files\Serviio\log\serviio.log" to "C:\Program Files\Serviio\log\serviio log.old"
  • Restart your PC
  • If Serviio isn't running (wait a few minutes after the PC restarts and start the console) then check "C:\Program Files\Serviio\log\serviio.log" to see why it hasn't started (or post the contents here and someone can help)
