[SOLVED] how to play .ape file
gonwg
Post Wed Dec 16, 2015 12:53 am
I installed the Serviio 1.5.2.
I have some .ape sound files. I wonder whether Serviio can play those files ?
Please help.
Post Wed Dec 16, 2015 1:06 am
Re: how to play .ape file
It isn't a matter of Serviio "playing" them, but your DLNA player supporting the format. I did a quick search to see of FFMPEG supports .ape, and it appears it does. So, if your player doesn't support ape then your files need transcoding.
Frankly, if they won't play native I wouldn't bother with transcoding, as you'll likely lose the high quality of the lossless original. I could be mistaken, and FFMPEG may be able to convert your files to a format your player supports without losing quality. I don't know enough about the whole transcoding process to be sure. If you can't play them without transcoding, you might as well convert them to something that your player supports. I'm sure converting to MP3 will cause a loss of quality. I just don't know how much.
gonwg
Post Wed Dec 16, 2015 3:47 am
Thanks for the reply.
My DLNA player is oppo bdp-105, which can play the .ape file natively. Because it plays the .ape file when I save them to a USB disk.
Does it mean that I should use some specific profile for oppo bdp-105, instead of the generic profile ?
Any advise ?
Post Wed Dec 16, 2015 8:39 am
ape is supported - see http://www.serviio.org/features.
Transcoding to another lossless type (eg. LPCM) can be done so that it does not result in loss of quality. Transcoding to a lossy type such as MP3 will result in the loss of some quality (similar to if you had encoded to MP3 in the first place).
Just because it works via USB doesn't mean it will work via DLNA. Do you see mp3 files in the same folder?
gonwg
Post Wed Dec 16, 2015 12:53 pm
DenyAll wrote:ape is supported - see http://www.serviio.org/features.
I see the mp3 files in the same folder and oppo player plays them correctly from serviio.
Any instructions on how to do the transcoding?
Sent from my SM-N910W8 using Tapatalk
Post Wed Dec 16, 2015 8:15 pm
Use the Denon AVR profile
gonwg
Post Thu Dec 17, 2015 12:50 am
[SOLVED]Re: how to play .ape file
I created a new profile by copying the Denon VAR profile, Serviio works perfectly for the ape file.
This is what it looks like:
<Profile id="oppo-105" name="Oppo BDP-105" extendsProfileId="1">
<Detection>
<UPnPSearch>
<FriendlyName>OPPO BDP-105</FriendlyName>
<Manufacturer>OPPO</Manufacturer>
</UPnPSearch>
</Detection>
<ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.SimpleContainerContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
<Matches container="mp4" />
<Matches container="ogg" />
<Matches container="wavpack" />
<Matches container="mpc" />
<Matches container="ape" />
</Audio>
Post Thu Dec 17, 2015 1:32 pm
Make sure you save a copy of your new profile. Any time you upgrade Serviio your profile file is replaced. While it's backed up, it's simpler to make sure you keep a working copy. :D
Users browsing this forum: Google [Bot] and 36 guests
